Paint or not? - Fiberglass RV
Old 10-01-2017, 09:10 PM   #1
Trailer: Trillium 1979 13ft.
Paint or not?
Any pros or cons about paintng front propane regulator to better blend in with Boler bottom? Want it to be less conspicuous!
Butsky is offline   Reply With Quote
Old 10-02-2017, 01:29 AM   #2
Trailer: Trails West
Doing an image search I did see some that came painted in green, brown or red. But I also found what might be a practical solution to your cosmetic concern, you could even paint it should you want a different color. It is a plastic cover that fits over the regulator to clean up the appearance. Inexpensive and since it snaps on the job is accomplished in a few seconds versus trying to get a regulator cleaned up, then masked and then painted.
https://www.campervan-hq.com/product...over-two-stage
Old 10-02-2017, 04:30 AM   #3
Trailer: Boler 1700
We have a camco regulator cover on our trillium. We purchased it from Amazon.
Lisa in Michigan is offline   Reply With Quote
Old 10-02-2017, 06:24 AM   #4
paint
I don't see why it would matter one big I would do it!!
Old 10-02-2017, 11:23 AM   #5
Trailer: Casita 17 ft. Liberty Deluxe
Painting Regulator
I would avoid getting paint in the vent hole.
J Ron is offline   Reply With Quote
Old 10-02-2017, 06:17 PM   #6
Could cause malfunction if it gets into the wrong places. Buy a cover or leave as is.
Old 10-02-2017, 08:56 PM   #7
That would be the only thing keep paint out of there I like it
bob
Old 10-03-2017, 01:17 PM   #8
Cover fitment
Cant find a cover for this!
Old 10-03-2017, 01:24 PM   #9
i think this is what is suggested.
Old 10-03-2017, 02:04 PM   #10
regulator cover
I run a single tank, no battery, regulator mounted on plate that is riveted to front of Boler shell. Two diaphrams, one above the other. This cover doesn`t look like it would fit, really. Am I not seeing something?
Old 10-03-2017, 02:12 PM   #11
A picture would help.
Old 10-03-2017, 02:59 PM   #12
Cover
picture in my post #8
Old 10-03-2017, 03:21 PM   #13
That's a picture of a regulator, not of your setup. If we had a picture of your setup, someone might have a solution that doesn't involve painting the regulator.
Old 10-03-2017, 07:28 PM   #14
rbryan's Avatar
Arkansas
I've painted a regulator before. It does no harm at all. Just mask over the adjustment screw cover (the blue one in the photo). Also tape over the bottom hole and hose inlets. Use a primer for galvanized metal, followed by a gloss enamel of your choice - hopefully one that comes close to matching your Boler's shell. I used a small paintbrush, but I see no reason why you couldn't spray it as long as it's masked.
Old 10-07-2017, 10:25 AM   #15
I would not put a cover over a propane tank for any reason if you want to go for it just not for me!
bob
Old 10-07-2017, 10:26 AM   #16
I just put a new hose and regulater on my rig the way it sets I don't hardly see it a waste of time to me!
bob
I think a Scamp is rediculous
paint
To paint or not to paint? Anita Modifications, Alterations and Updates 12 02-13-2016 01:03 PM
Paint over resin paint? Joan of Shark Modifications, Alterations and Updates 4 08-02-2014 08:25 AM
Insulation - to paint or not to paint? Trillium.Stella Problem Solving | Owners Helping Owners 23 09-04-2012 10:46 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 11:39 AM
To paint or not to paint andrew ferguson Care and Feeding of Molded Fiberglass Trailers 8 08-14-2007 07:02 PM
