Paint was applied with the roll and tip method. Prep is the most important part. Sand and fill any pin holes before priming. Clean with acetone. I put 3 coats of primer, sanding between coats and 3 coats of white. Again sanding between coats. The stripes and front lettering were painted on as well, 3 coats.
https://youtu.be/FJ_T84GU_as
