05-08-2021, 10:21 PM
Question about jackstands
I have seen it recommended to use a jack and jackstand when servicing the bearings & wheels (on my Scamp 13). However, when I purchased a jackstand for this purpose, the label on the device specified that it was not to be used on an RV or travel trailer. Can anyone help me to understand why? It also specifies using the jackstands only in pairs rather than on only the side being jacked up for wheel service. Are there any jackstands approved for RV's? Thanks.
Erik in Oregon
05-09-2021, 02:23 AM
Trailer: Roamer 1
Smith Valley, Nevada
I wonder if it means not to use it for leveling or stabilizing?
05-09-2021, 10:42 AM
Jackstands
I use maintenance jack stands for only maintenance on my trailer but not for long term support. This may be what the manufacture is meaning.
A maintenance jack stands are typically ratchet or pin (not common) adjustment. This means you need to lower the vehicle (trailer) on to the jack.
RV jack stands are screw adjust and can be raised to match the vehicle (trailer). Also, the RV jack does not have a quick release like a maintenance jack stand, thereby providing more stability for long term usage.
As for using two jacks, this is a standard practice to ensure that the raising of the unit is even and stable. Since, my trailer has a frame, as most do, I used only one maintenance stand under the axle when I am performing work on the bearings. I raise the trailer using a bottle jack, lower the frame onto the maintenance jack stand and leave the bottle jack in place.
Keep in mind that the with any jack the load limit should never be exceeded.
05-09-2021, 11:30 AM
Trailer: 2013 Escape 19
Years ago I bought a set of automotive Jack stands. The label included a lot of warnings including: “Do not use to support a vehicle” and “never work underneath a vehicle supported by these stands”.
Seems like their lawyers were working overtime..
05-09-2021, 12:30 PM
Trailer: Trail Cruiser
I've used jack stands to support my trailer for years with no problems. A piece of 2x10 helps to prevent sinking on soft surfaces. My main reason for not using them is they often get stolen if the trailer is unattended.
05-10-2021, 07:04 AM
Definitely a load of "Lawyer-ese" at its finest. It's right up there with "Don't use this 120 VAC toaster in the bathtub." It's all CYA product liability protection for their product so they don't get sued by people too stupid to use a product safely or as it was intended to be used.
Why else would you buy jack stands if not to insure the rig won't come down if the lifting jack fails? Duh?
05-15-2021, 10:16 AM
Trailer: Casita 17' LD
Erik in Oregon
There is a reason for using jack stands on both sides. Using a jackstand on only one side leaves the trailer supported by one jackstand, one wheel, and the tongue, whatever it is sitting upon like dirt or wooden block. OK, so the wheel can roll, and the tongue can slide sideways and the jackstand tip over----all at the same time. Needless to say, it is coming down when that happens.
An even better suggestion is to have the tongue hitched to the tow vehicle so it can't slide sideways.
05-15-2021, 11:35 AM
What kimd of jack stand do you have? A maintenance jack stand would be the ones to use. A stabelizing jack stand is so ething else.
05-15-2021, 12:18 PM
If I were going to be under the trailer with the wheels off, I would want some redundancy in the jack stands.
I'm thinking of the recently recalled units from Harbor Freight that did not fully engage the stops and were prone to drop down without warning. I know HF is known for cheap products, but you just never know.
05-15-2021, 12:30 PM
Mid Left Coast
^^ +1 !!
05-15-2021, 02:07 PM
Trailer: Gulfstream
Memphis
There was even a thief killed recently trying to steal a Catalytic and his jack failed, car fell and killed him
05-15-2021, 06:56 PM
Trailer: Scamp Deluxe 16ft
Alabama
Frank R. Is spot on about having something to "lock it down" from shifting while working on it. A norm for jack stands is to have other axle tires blocked in place or totally on stands the latter has "let" some people down in the past too.
05-15-2021, 06:57 PM
Alabama
"That sounds like it worked out well, for everyone else around there.
05-15-2021, 07:37 PM
Trailer: 2013Escape 21
Iowa
Jack stands
I prefer to be hooked up to the tow vehicle but if not I put four chocks on the opposite side tandem tires, leave the big three ton floor Jack up against the frame and use two three ton maintenance Jack stands to assure front and back stability. On the front Jack post if not hooked up I use a large piece of roughy lumber that won’t slide on the concrete floor. I don’t work in the grass or gravel unless it’s an emergency which hasn’t happened on any trailer I’ve owned. Of course I have a good changing a tire in the dark story for another time.
Iowa Dave
05-16-2021, 09:14 AM
Iowa Dave and me, thats how I do it too. Must be an Iowa thing, me, from Fort Madison.
05-16-2021, 01:15 PM
Iowa
Fort Madison
As a town with an historic past and some neat features, I like Fort Madison. I had a friend who was the Parks and Rec Director there. His name was John Brenna. That was in the late 80s and early 90s. He put on a good fall workshop once. Further down the road is Keokuk. If you blink, you’ll miss it and soon be in Misery.
Haven’t been to Fort Madison for quite a few years but do see the big crowbar hotel they have there on TV occasionally.
Iowa Dave
06-25-2021, 07:28 AM
Trailer: Escape
New Mexico
I admit I often don't know Jack. And I'll stand by that.
06-27-2021, 08:16 PM
Trailer: Bigfoot
Everywhere
Were they from Harbor Freight? With all the recalls that warning might have actually been legit..
