As Gerry and Raspy stated , you need to troubleshoot your system in parts not as a whole. Start with as Gerry suggested , charge up your
battery , disconnect the
battery from all loads and see if it holds a charge . If your battery is good then reconnect the charged battery and test with an amp meter to find out if there is a load on the battery.
If there is a load on the battery then test to see which DC circuit is drawing current.
You may have a resistance short in one of the DC circuits .
The resistance may be low enough to cause the battery to slowly drain but too high of a resistance to blow a fuse.
