I have an older (2003) dometic
refrigerator that is freezing foods in the
fridge compartment even when the thermostat dial is set on number 2. The location of the thermister is not adjustable. It is held in place within the fins behind a thin aluminum panel with two screws. ( Photo orientation is off. Left side of foto is top of
fridge, right side is bottom, wirebis thermister) I think this is part of the original design for this model as there is no option for changing the location in the operation manual.
I'm assuming it may be a resistance problem in the thermister, but do not know how to check for this. Also it looks as if I'd have to pull the
fridge to replace the thermister which is beyond my DIY skills.
Any suggestions regarding the thermister.
The freezer door is operational, no
leaks.
Anything else that I should check that might be causing the problem?
Scott
