Reinstalling the belly band on my boler. Rivets or screws? - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Care and Feeding of Molded Fiberglass Trailers
Click Here to Login
Old 04-24-2021, 10:15 AM   #1
Trailer: Boler 1300
With the paint done on Lita now it's time to reinstall the belly band.
When I removed it a lot of the rivets had loosened off and it was only riveted through the top fiberglass lip. Now that it's going back on I was thinking of using #8 ss machine screws through the channel so it fastens through the top and bottom lip secured with nylock nuts on the underside of the channel.
I'm definitely not concerned about keeping it all original and aesthetically think screws would look fine. Mostly just wondered if anyone out there sees any obvious mechanical or other issues?
Thanks in advance!
Bob
bobdobqb is offline   Reply With Quote
Old 04-25-2021, 05:14 PM   #2
Trailer: 1971 Hunter compact Jr, 1979 Terry 19', 2003 Scamp 16'
I have not used screws in fiberglass. That being said it have experience with wide range of other materials. I would expect screw threads tare through fibrous material as thin as a fiberglass trailer. I believe you need surface area on both sides of the hole. Maybe machine screws with nuts and washers. I would stick with stainless steel pop rivets. Just an opinion.
Terry in Fowler is offline   Reply With Quote
Old 04-25-2021, 09:06 PM   #3
Trailer: Boler 1300
Thanks Terry. I was certainly thinking that machine screws would be what I'd use but on reflection I might just go back to rivets.
Old 04-26-2021, 02:42 AM   #4
When you rivet the band back on as you know the rivets generally penetrate the top of the lip. This opens up the possibility of leaks from water collecting on the top of the band and lip leaking into the cavity formed by the junction of the two parts and the fiberglass mat joining them on the inside.
This cavity can be formed and carry water that leaks in quite a distance from the leak.
Be careful to caulk the top side of the band only so that any water that gets in behind the band can leak outside and also take care to seal the joining area as carefully as you can.
I would not worry about installing a large number of rivets as the band, once riveted on the ends and a few spots around the trailer will not come off, but each river offers a place to leak and any hole that allows water ingress is a problem.
Use a good quality sealant to caulk the top of the band to the trailer side and no sealant on the bottom.
Been there and done that!
In my case I had a leak that showed up as a leak at the junction oc the belly band backing and the front of the door jamb. The actual point of water ingress was in the front of the trailer, probably 4 - 6 feet away.
Old 04-26-2021, 04:05 PM   #5
Trailer: Boler 1300
Thanks JD. I was also thinking of maybe using some sikaflex or 3M 4200 to seal the area between the 2 lips which would also keep the water from the joint area. The band previous had no sealant at all on the top side.
Old 04-26-2021, 04:21 PM   #6
I don't think I would use 4200 as someday someone might want to take it off.
I fought that leak and fought that leak, even grinding a vee in the gap between the two "lips" and stuff in epoxy resin.
That gap was what was letting the water get into the cavity formed by the glass mat joining the two halves. It ran from about 1/2 way around the curve to the front of the door jamb and leaking into the closet I had built by the door.
I think the key is to just get a good seal at the top of the band and let whatever might get between the band and the shell run out.
Old 04-26-2021, 08:46 PM   #7
Trailer: Boler 1300
Thanks a bunch!
Old 05-05-2021, 10:06 PM   #8
Borden's Avatar
Name: Borden and Carole
Ours is factory-installed rivet but used small 1/2" #6 stainless screws in to spots predrilled for repair.
Our postage stamp in heaven.
Old 05-06-2021, 06:07 AM   #9
I’d use rivets, especially since it’s non-structural and non-stressed. Rivets are smooth and will not rust. Screws can work loose, and the threads can wallow out the holes with time and vibration.
Put a dab of non-permanent, non-silicone caulk in the hole just before you pull it. Caulk the top side betwee the band and the shell after installation to keep water from running behind the belly band, where it can freeze and open the seam. Agree with not caulking inside or under to let any water that gets past the caulk have an exit path.
Old 05-06-2021, 09:10 PM   #10
Trailer: Boler 1300
Thanks folks!! I always appreciate the input here. Think I'll go back to rivets and do the sealing as suggested. Have to finish this off and get ready for camping!!
Old 05-08-2021, 11:17 AM   #11
Just know that the rivets are aluminum and won’t rust. These stainless steel screws are no doubt Chinese and will rust. They are not the rust proof variety.
barrry smithe is offline   Reply With Quote
boler
Reinstalling jalousie windows boler Taybolers Problem Solving | Owners Helping Owners 2 06-15-2019 01:58 PM
Rivets for 73 Trillium Belly Band ChrisH Problem Solving | Owners Helping Owners 3 03-26-2018 12:16 AM
Reinstalling furniture in a boler Dee.C. Problem Solving | Owners Helping Owners 2 03-26-2017 12:18 PM
Where can I find that rubber trim that covers the screws on the belly band? MoDZuKi Modifications, Alterations and Updates 3 09-21-2015 09:38 AM
reinstalling fixtures without rivets Cat futrell Problem Solving | Owners Helping Owners 11 10-29-2012 10:03 AM
