08-11-2020, 09:01 AM
Trailer: Helio O2
repairing bubbling/cracked gel coat around Tacoma, WA?
Hi guys, this is about my Helio O2, which has a gel coat exterior so I figured someone here may be able to suggest a repair shop in the Tacoma, WA, area.
I noticed the other day several bubbles on the exterior gel coat. I poked one of them and it ended up cracking. See attached photo. There are no Helio dealers near me in WA, so they asked me to get estimates for repair at a local place. I just moved to WA, so I have no idea who can help repair this.
Can someone recommend a good gel coat repair shop in Lakewood/Tacoma, WA?
One photo shows the crack, the other two photos show other bubbles that will most likely crack if I poke them.
08-11-2020, 09:42 AM
Talk to these guys. They completely rebuilt our Casita after it got crunched by a tree. They are pretty close to you.
https://www.wescraft.repair/
Good luck.
08-11-2020, 09:43 AM
Trailer: Helio O2
Originally Posted by Dave Fish
wow they're only 15 miles away. thanks!!!
08-20-2020, 06:07 AM
Trailer: Burro, HELIO
What did the folks at HELIO tell you caused the cracks/bubbles to occur? I have a Helio O3, a 2020, I live in Seattle.
Think Positive Thoughts...........
Happy Trails, Life is Short....Camp Often!
John
08-20-2020, 06:23 AM
Trailer: Helio O2
They've been less than helpful. They said they'd send my pics to the gel coat distributor and find out what happened but I never head back on it. They asked me to get a quote to fix it, so I sent them the quote from Wescraft. They came back and said the quote was too high and it should only cost 1/4 of the quote. I asked them to cover a little over half and I'd cover the rest, but no response. I love my Helio but they're not very helpful when you need them.
If anyone wants to buy a practically brand new Helio O2 with very minor gel coat issues, hit me up. 😊
08-20-2020, 06:51 AM
Trailer: 1979 Boler 1700
I would guess this is NOT a gelcoat problem, but voids in the substrate materials that occurred during manufacture. Patching the voids is simple, but repairing the gelcoat in a way that it blends seamlessly with the original surface, and matching the color could be difficult.
08-20-2020, 07:01 AM
Agree. It is definitely a manufacturing defect in the fiberglass molding process, not impact damage, and yes, it can be repaired to be virtually unnoticeable.
Get a second quote and insist they cover 100% of the repair. Auto or marine repair shops that work on fiberglass can handle it. Ask the repair shops to give you a written description of the damage and cause.
Very disappointing!
08-20-2020, 07:08 AM
Trailer: Helio O2
They said it should take an experienced person 2 hours to fix all these bubbles and crack. They want it fixed it cheaply as possible while i want it done right. They did offer to make a video on how to do this repair to send to Wescraft, because apparently spending time to do it right means you don't know what you're doing. Lol. Helio's response to this warranty issue has been less than ideal.
08-20-2020, 07:22 AM
Trailer: Helio O2
I sent Helio a reminder email and they just responded that they're trying to locate a marine repair shop in WA that will fix this under warranty. Will keep everyone posted.
08-21-2020, 10:45 AM
this is caused by an air pocket the layup was not rolled when the resin and fiberglass were put into the mold after the gell coat was put in. I suggest you check your fiberglass shell for issues like this on all outside corners and circle them with grease pencil and take pictures. Do this while they admit a problem and while its under warranty. gel coat shrinks while it ages so these type of problems if prevalent will show up. if its only 2 hours work then they should send out a tec to fix it. if its brite white it is an easier fix than mixing gell coat an off white color.
