Scamp tail lights - Fiberglass RV
Old 04-28-2021, 06:08 PM   #1
Scamp tail lights
I know the old joke about how many people does it take to change a light bulb, but we could really use some ideas.
Issue: Taillight bulb blown. terminalsPurchased bulbs. the are apparently getting contact but still no light with new bulb An auxiliary set of lights installed ( at Backus) about 15 inches above the original set a couple of years ago and it went off once we got the old bulb out from the light with the initial problem. This issue is on only one side. Left side is in perfect working order. Your thoughts would be appreciated. Barb & John
mspgaff is offline   Reply With Quote
Old 04-28-2021, 08:38 PM   #2
AC0GV's Avatar
Wisconsin
Volt meter?
Have you had the volt meter out? Both tail and brake lights? If you are not getting the voltage on the bad one, use the working one as the negative contact for the meter as the problem could be the ground. Are you sure that the new lamp has two contacts (1157). It's also good to use tune up grease on the lamp base when changing them to keep the green stuff from forming.
Please let us know what you find.
Old 04-28-2021, 08:46 PM   #3
Dan Meyer's Avatar
Move the bulb from the other side to the non-working side.
Check fuses in the tow - mine has separate fuses for each turn signal and tail lamps for the trailer connector.
Give the connections in the storage area under the dinette seats a look. Pay close attention to splice in the green wire - this is the ground wire for all of the turn/brake/tail lamps. See your owners manual for a wiring diagram or look here: http://scamp.n0kfb.org/Manual/electrical.jpg
Good luck, and keep us posted!
--Dan Meyer
Old 04-29-2021, 11:40 AM   #4
Massachusetts
When you said "and it went off once we got the old bulb out from the light with the initial problem." did you mean that the upper bulb did not light when the bottom bulb was removed?
Sounds as if something was wired in series and that circuit was broken when the bulb was removed. I'd check the wiring with an ohm/volt meter to see if things are wired correctly. They should have or were suppose to wire them in parallel, at least I would have. I'd also check their connections where they wired in the new upper lamps.
Lockman is offline   Reply With Quote
Old 04-29-2021, 09:53 PM   #5
Trailer: 2013Escape 21
Iowa
Those grounds and the corrosion in the sockets can mess you up.
Iowa Dave
Iowa Dave is offline   Reply With Quote
light, lights, scamp, tail lights
Tail lights, marker lights, reflectors jeroen Modifications, Alterations and Updates 15 10-30-2017 06:06 PM
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
Wiring Scamp tail lights Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 06-01-2003 08:50 PM
