Scamp Tailight Troubles - Fiberglass RV
Old 09-28-2021, 10:52 AM   #1
Trailer: '95 Scamp 13 Standard
NM
At the end of our recent camping trip we discovered that the right side taillight was not working for night and blinkers. I've switched the bulbs from one side to the other to check if a bulb was bad, no change, problem stays on right side. I've checked the cable from the outside 4-pin connector to the Jeep using a voltmeter, good connectivity.
So my question is whether anyone has had a similar problem and if there is a common fix. Any and all suggestions will be appreciated.
pastor-russ is offline   Reply With Quote
Old 09-28-2021, 01:40 PM   #2
Trailer: Scamp 1995 19'
Did you check the pigtail on the tow side?
If the wire from the connector to the light is good, then perhaps it is in the side on your tow vehicle? Are you getting a voltage bouncing when the turn signal should blink?
JWColby EAAT
Exalted Arbiter of Anal Tripe
jwcolby123 is offline   Reply With Quote
Old 09-28-2021, 03:01 PM   #3
sokhapkin's Avatar
SW Florida
I suspect the problem is in the ground wire in that light.
Sergey
www.callwithus.com
Old 09-29-2021, 11:36 AM   #4
North Dakota
We had a similar problem and, after messing around with it, the light began working again. At least for now. No idea what happened there.
Linda M R is offline   Reply With Quote
Old 09-29-2021, 12:14 PM   #5
dfandrews's Avatar
Trailer: 2015 Escape 17A
Over the last many decades, I've found that vehicle lighting problems, especially in trailers, are mostly because of poor grounds. Start by checking all the ground connections that are a screw into a frame member. Unscrew and clean to bare metal. rust/dirt/corrosion is not conductive!
Don & Teresa
Tow: 2011 Honda Pilot
Trailer:2015 ESCAPE 17A
RLTW - LRRA2015
dfandrews is offline   Reply With Quote
Old 09-29-2021, 12:45 PM   #6
Having one of these will save the day. Even cheeper when they have a sale.
https://www.harborfreight.com/12v-ma...kit-64282.html
Old 09-29-2021, 05:52 PM   #7
not to hijack the thread
But if I remove the lense to replace the bulb with a bright led, is the seal reusable? Am I headed for trouble with a water leak? Any recommendations for bulb replacement?
JWColby EAAT
Old 10-11-2021, 09:50 AM   #8
Trailer: boler
Had a similar problem with the boat trailer. A bit different because on the boat trailer the light bolted to the frame and that is where it grounds. But on our boler the tail lights need a wire from the tail light to a ground. Invest in a cheap test light for couple of bucks. Run a wire from a power source say your jeep with test light on end, then touch the bulb holder in tail light, if the test light doesn't come on you have a gound problem. Should work both ways ground to power or power to ground the light should come on. You need to follow where the ground comes from can check on way with probing into wire with your test light this will check for broken wire. Usually though it is usually a dirty or rusted connection. Good luck.
Nancy F is offline   Reply With Quote
Old 10-11-2021, 01:35 PM   #9
Trailer: Scamp 19
SE shore Lake Erie In Cattaraugus County
It should just snap off and snap back on.
parmm is offline   Reply With Quote
Old 10-11-2021, 01:37 PM   #10
Trailer: Scamp 19
Except for the bumper, where will they attach to. The bumper does not offer a lot of area to attach to.
light, scamp
Surfside tm-14 tailight lens KLAUS TIEKENHEINRICH Classified Archives 1 07-12-2011 10:00 AM
LED tailight mod..... kentj Modifications, Alterations and Updates 6 06-18-2008 09:48 AM
Scamp LED Tailight Replacement Greg A Modifications, Alterations and Updates 11 11-06-2007 10:32 AM
Broken Boler Tailight Mario H. Castillo Problem Solving | Owners Helping Owners 0 05-17-2007 06:33 PM
Tailight Question Ken Ford Problem Solving | Owners Helping Owners 5 05-14-2006 03:28 PM
