sealing rivets on scamp roof - Fiberglass RV
Old 04-16-2024, 09:44 AM   #1
Trailer: Scamp 5th wheel
I'm wondering if anyone has tried Rustoleum Leak seal spray to seal rivets on top of a Scamp
patsublett is offline   Reply With Quote
Old 04-16-2024, 10:55 AM   #2
ShelbyM's Avatar
Trailer: Casita SD
FWIW, it's not that hard to do it right. It seems scary but once you do a couple it won't take any longer than reading this post.
If the shoe fits...
Old 04-17-2024, 07:35 AM   #3
what is the proper way
Old 04-17-2024, 12:55 PM   #4
ShelbyM's Avatar
Trailer: Casita SD
Drill out the old rivet and replace, along with a new base and cap. There are instructions and videos if you search and you can order the parts from Scamp
If the shoe fits...
Old 04-24-2024, 11:21 AM   #5
NOD
NOD's Avatar
Trailer: 1977 Scamp 13'
The only way you’re going to effectively deal with leaky rivets is replacing the rivets. Fiberglass trailers flex a lot, and eventually things are going to loosen up. Add a tiny amount of butyl rubber to the top of the rivet shaft before installing through the trailer and you’ll be assured a leakproof seal for a long time.
NOD is offline   Reply With Quote
Old 04-24-2024, 11:24 AM   #6
GOB
Trailer: Scamp 19
Replacing rivets
Wife and I replaced ALL the rivet in our Scamp 19 in a couple of hours. We used new DEC caps, stainless steel machine screws w/nyloc nuts. A small amount of Buytle tape under the DEC base before installing. Don'i over tighten. Replace one at a time. Pretty simple once you do a couple. No more leaks from popped rivets.
GOB is offline   Reply With Quote
Old 04-24-2024, 11:29 AM   #7
I replaced all of the rivets in my Scamp with stainless steel screws washers and cap nuts along with the snap caps and bases from Scamp with a dab of caulking.
John LF is offline   Reply With Quote
Old 04-25-2024, 12:01 PM   #8
Trailer: '06 Scamp 16
Rochester, New York
Each time a rivet comes loose, I replace it with SS, butyl caulk, snap cap, and a nylock nut. SS washer in cap and under nut. No repeat problem at that spot. Never bothered to do them all at once.
Sealing around vents on fiberglass roof (Bigfoot) oldsgg Care and Feeding of Molded Fiberglass Trailers 14 08-07-2020 06:24 PM
Roof Sealing? kiyiyi Care and Feeding of Molded Fiberglass Trailers 3 06-05-2018 09:50 PM
Sealing the roof of older Bigfoot blacklab Modifications, Alterations and Updates 4 05-06-2016 02:23 PM
Sealing Burro roof Suki Problem Solving | Owners Helping Owners 11 04-04-2014 07:04 PM
Sealing roof perforations-Bigfoot Tony Nowak Problem Solving | Owners Helping Owners 2 07-15-2009 11:48 PM
