Trillium roof - Fiberglass RV
Old 12-23-2019, 07:43 PM   #1
Trillium roof
Trying to insulate the garage where the trillium is. Is the roof strong enough for 170lbs on it. Has anyone done this?
agreco is offline   Reply With Quote
Old 12-23-2019, 11:01 PM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
NO it is not, but if you shore up the roof from the inside with plywood and bracing from the floor to the plywood, you might be able to apply some of your body weight if spread out.
Best of luck.
Dave & Paula
Old 12-24-2019, 08:05 AM   #3
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
Definitely not!!
Old 12-24-2019, 10:55 AM   #4
Raz
Raz's Avatar
Vermont
When I replaced my roof fan I was able to put my full weight on the lower part on the kitchen side of the roof by staying close to the edge and using a piece of foam board to distribute the weight. I would never get on the center section of the roof even if it was supported inside. If I were doing what you are, I'd either move the trailer or perhaps rent some staging. Cheaper than repairing a caved roof. Good luck. Raz
trillium
Anyone know how to fix a saggy roof in a Boler??? (around roof vent) idiotsniff Problem Solving | Owners Helping Owners 31 11-17-2014 06:50 AM
Removing Roof Rack and Patching Screw Holes in the Roof Roger M Modifications, Alterations and Updates 4 02-08-2012 11:40 AM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
Fiberglass roof replacement of rubber roof Scott Kominkiewicz General Chat 1 08-16-2007 07:13 PM
Fiberglass roof replacement of rubber roof Scott Kominkiewicz Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
