Velcro and suction cups - Fiberglass RV
Old 05-06-2020, 08:37 PM   #1
Trailer: Burro
One of the things I like about having a smooth fiberglass interior(Burro), is I can experiment with modifications just using Velcro and suction cups to decide if the prototype suits my needs.
For example, I hung a sailboat style hammock/storage net from 2 suction cups, wondering if I’d use the extra space. After a couple of trips it was really handy, so I left the suction cups up with the storage hammock- they are really strong.
Made a counter extension out of the stove cover by putting some Velcro next to the stove top, moved the plywood rectangular box(stove cover) to the right, with Velcro on the bottom edge. Made a leg to support the free end, attached with Velcro to the inside edge, and a square of Velcro on the bottom.
Great shelf- counter space, and now I have a place to put the stove cover when I need the stove.
No end to simple little add ones with Velcro and suction cups, and no holes drilled.
Velcro sticks to the carpet roof to hang solar lights- probably all knew that.
Burroman is offline   Reply With Quote
Old 05-07-2020, 04:57 AM   #2
Brian G.'s Avatar
Trailer: '73 & '74 Hunter
That's a good idea Larry; I might try the Velcro method. But is it difficult to remove the adhesive if you decide you don't like the modification?
Brian G. is offline   Reply With Quote
Old 05-07-2020, 06:48 AM   #3
Raz
Raz's Avatar
Vermont
I found that sooner or later suction cup let loose. Command hooks work well and can easily be removed. To remove velcro a hair dryer, a dull putty knife, and Goo Gone works but you have to let the Goo Gone sit for a while.
Old 05-07-2020, 07:33 AM   #4
Trailer: Burro
Yep, suction cups are not forever.
About ready to change out the hammock storage area for command hooks, now that I’m convinced it’s something I want to keep there.
Had it there for 3 trips and it never budged- but, it will fail.
Did the screen door with Velcro tabs around the perimeter of the door opening.
Got a magnetic, center closing mosquito net and it works great.
Yep, suction. Ups, Velcro, command hooks in that order.
Old 05-07-2020, 09:13 AM   #5
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I use a lot of the “industrial strength” Velcro (I typically purchase it at Lowe’s) on bare fiberglass, and have found that most of the adhesive comes off when the Velcro is removed, and what is left are small patches of adhesive and not a layer the same size or shape of the piece of Velcro removed. I have always been able to remove what remains by pressing the piece removed onto the patches and pulling it off. What little that may remain I find I can remove by rolling it with my thumb. When finished, if there are black smudges left behind, a bit of lighter fluid on a paper towel easily removes them. I really prefer Velcro rather than drilling holes or using double-sided foam tape.
Old 05-07-2020, 03:17 PM   #6
Brian G.'s Avatar
I was curious …
Wikipedia says Velcro was coined from the french words Velour Crochet (“velvet hook”). George de Mestral conceived his invention in 1941 when he went for a walk in the woods and wondered why burdock seeds clung to his coat. The product was introduced in the late 1950s.
burro
Tarp Awning - Fiberglass-safe Fluid for Enhancing Suction Cups junglejim83 Modifications, Alterations and Updates 29 10-04-2016 02:17 PM
Product testing: Harbor Freight suction cups rabbit Modifications, Alterations and Updates 10 06-12-2013 08:02 AM
Suction Cups, FG Camper's Friend D Davis Modifications, Alterations and Updates 14 08-01-2012 06:47 PM
Stronger than suction cups jamessue Care and Feeding of Molded Fiberglass Trailers 7 08-24-2009 08:35 AM
Velcro and awnings. Rozanne G Problem Solving | Owners Helping Owners 16 06-23-2008 12:35 PM
