Water pressure pump in 16í Scamp, 12v. - Fiberglass RV
Old 07-09-2018, 09:35 AM   #1
Dsironi's Avatar
Trailer: 2013 Scamp 16'
Wisconsin
When the switch is on, is the pump using electricity?, or only when pumping?
Headed RMNP and want to conserve battery power.
Thanks
Dsironi is offline   Reply With Quote
Old 07-09-2018, 09:40 AM   #2
It's not advisable to leave the pump turned on in any case. If a tap somehow gets turned on or if there is a leak in the plumbing, you can fill your trailer with water and empty your fresh water tank.
Old 07-09-2018, 09:46 AM   #3
Dsironi's Avatar
Wisconsin
Great advice. Didnít think about what could go wrong. Leaking could occur if connected to city water too.
So, I accept the advice. But does the pump draw current when idle?
Old 07-09-2018, 10:36 AM   #4
Trailer: Currently Shopping
NO ; if the pump motor is not running / pumping then no power is being consumed . The pump is controlled by a simple pressure switch (On or Off) and the switch does not consume power. IE ; NO phantom load
Old 07-09-2018, 10:46 AM   #5
Trailer: '06 Scamp 16
Rochester, New York
The pump only draws power only when pumping, unless it's not properly adjusted.
Easy check: Unplug shore power so trailer is on battery only and turn on a light.
Light will probably dim when water is used and return to full brightness when not.
If light stays dimmed, pump pressure switch needs adjusting.
As already stated, switch should be off when water is not needed, especially when you are away from the trailer or towing.
Old 07-09-2018, 10:59 AM   #6
Dsironi's Avatar
Wisconsin
Thanks to all of you.
Adding a 12V Water Pump Thee Jimbo Modifications, Alterations and Updates 17 06-23-2013 08:21 PM
Water pressure or pump problem? Janb313 Problem Solving | Owners Helping Owners 10 06-19-2013 10:41 PM
12V Water pump for 78 boler? BolerBrad Problem Solving | Owners Helping Owners 2 07-28-2012 11:50 PM
12v Electric Water Pump/Faucet Kit w Maintain Switch John L. Problem Solving | Owners Helping Owners 12 03-31-2007 02:18 PM
boler 12v water pump and switch iaian pettit Plumbing | Systems and Fixtures 10 01-12-2007 01:07 PM
