Originally Posted by Mike_L
I have a small, portable battery powered pressure washer that I use to wash my ATVs and trailer. It doesn't have a high pressure so no concerns with forcing water through window/door seals etc. but does a good job of removing dirt and road debris. I can add an automotive or boat cleaner as necessary.
I also have a battery powered buffer that can be used to remove oxide when used with almost any automotive polish. More aggressive products can be used if the oxide is significant. Products designed for fiberglass boats seems to work best.
I agree -- about the boat products. So many like to use the wax-based products designed for cars. However, wax oxidizes and yellows in the sun, so even if it gives a slightly more shiny effect for a while, it has to be done several times a year. Otherwise, old wax left on a white
fiberglass trailer will turn a very dull yellow.
As I have said here a couple of times, I have used a marine boat polish -- Starbrite (no affiliation, and there may be similar products_ -- for many years on my 2008
Casita. The trailer still looks very white and shiny -- almost as good as new. I only polish it about once a year to keep it looking that good.
To clean a FG trailer just use strong detergent and water. If you have stains you can get rid of them with sodium percarbonate (Oxyclean is a brand name, but I hate to give that obnoxious jerk a plug). Apply a heavy solution in bright sunlight. Sunlight seems to catylize iit's action. Just get all of the old wax and anything else that is coating the fiberglass.
With the Starbrite, they make a cleaner-polish that will remove most of any oxidized layer of gel coat. It goes on easily -- no electric buffer is needed. Then follow up with the Starbrite polish (that the manufacturer says contains teflon). The second polish application goes on so very easily...just wipe on, wait a couple of minutes to mostly dry, and then wipe off...no elbow grease required. Any area that does not shine completely can be addressed by softly wiping more polish on...kind of a spit-shine approach. You will see the surface getting smoother and more shiney with each spit-shine wiping.
Or you can buy a polisher, buff away a lot of the fiberglass gel coat with an abrasive rubbing compound, and then apply car wax every couple of months...the way it was done to your hot rod car in the 1960's.
Your choice.
Gator
