Window ooze - Fiberglass RV
Old 06-27-2018, 10:52 PM   #1
Trailer: Scamp 19 D 5er
North Dakota
Window ooze
Here is the problem. We have a 1999 5er. Around the window panes, there is black stuff oozing out. It looks like black tar and is pretty sticky. I tried using a razor blade to trim it but it just smears it worse. Has anyone had this problem? How did you clean it off of the window?
J. Sully is offline   Reply With Quote
Old 06-28-2018, 06:49 AM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
This sounds like the rubber seals are deteriorating. Or, does it ooze out of the weep holes in the frame? Dust, pollen and other material accumulates in the frame channels and it all needs to be washed out occasionally. Any pictures to help with diagnosis?
Old 06-28-2018, 08:46 AM   #3
Trailer: 2014 Escape 21, Lil Joe
Try mineral spirits for butyl base sealers on glass.
For window frames:
The frames windows normally come with a foam seal with limited life. When resealing windows they make a wide black butyl tape which is prone to ooze out during summer heat. To trim it off use a plastic putty knife (Wal Mart sells them. $.59) The plastic tip does not scratch your surface. Use the tip of the edge to go around the frame then remove the trimmed material. Mineral spirits cleans up the butyl tape residue off the trailer. I just re-installed two windows yesterday, cleaned up with no issues.
Eddie
Old 06-28-2018, 01:27 PM   #4
Trailer: Escape
Sounds like it may be rubber butyl sealant tape. I use a plastic putty knife to clean it up and have sealed some window gaps with caulking over the butyl to keep it from oozing.
Mineral spirits takes off some topcoat on my trailer so I use windex or acetone with an old scrub sponge to get off residue that the putty knife can't remove.
Thane is offline   Reply With Quote
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
74 boler - window and window seal Hans N. Problem Solving | Owners Helping Owners 4 12-08-2009 09:11 PM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
» Trailer Showcase
Casita
GlendaW
Baby
Lisasgirl
