Window Surround Question - Fiberglass RV
Old 08-01-2021, 02:51 PM   #1
TWelch's Avatar
Trailer: 2011 Egg Camper #101, the Abel Egg, pulled by 2019 Nissan PathFinder
Alabama
The following photos are of the windows on my 2011 Egg. What is the “ragged” stuff around the main rubbery frame? What should I do about it?
Thanks
Tonie
(and Abel, 2010-2018, always in my heart.)
in the Abel Egg, 2011 EggCamper #101
TWelch is offline   Reply With Quote
Old 08-01-2021, 04:58 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Its probably butyl tape which is a sealant applied to the back side of the window frame when it is installed on the body of the trailer. It keeps water out. The ragged edge of the sealant is the excess portion that has oozed out. You can scrape/cut it off with a plastic blade.
Eventually the butyl tape after 20 years or so begins to fail. Then the windows begin to leak around the outer edge. At that point, the windows should be removed, the old sealant scraped and cleaned off, and new butyl tape applied before re-installing the windows.
Old 08-01-2021, 06:48 PM   #3
TWelch's Avatar
Alabama
Thanks, John. Since it is 10 years old now, I am hoping it lasts for a while longer! I appreciate the info. Good know what to expect. . .
Thanks.
Tonie
Looking for window seals for Boler door window bomni Problem Solving | Owners Helping Owners 12 04-26-2012 04:51 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
74 boler - window and window seal Hans N. Problem Solving | Owners Helping Owners 4 12-08-2009 09:11 PM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
