I've completed stripping about half of my 17 ft
Casita. This is the procedure that I've found to be the most effective so far.
1. Spray 2'x2' section with Zep stripper
2. Squeegy off residue after about 30 sec to a minute.
(This is far shorter than recommended, but it reduces cycles needed to removed yellow stain]
3. Spray area again with stripper, rub with green scotchbrite
4. Squeegy off
5. Spray with TSP solution, scotch brite after 30 sec - minute and squeegy off
( This step lightens the yellow stain)
6.. Rinse with water
Repeat step 5 until yellow stain doesn't lighten 1 to 3 cycles)
7. Squeegy off
8. Rub with green scotchbrite and Bar Keepers Friend
9 Squeege off
10. Rinse with water (This step significant reduces yellow stain)
Repeat 8,9,10, until yellow stain (wax residue) has been removed to your satisfaction. Usually only takes 2 to 3 cycles.
This is a very time consuming process and I'd definitely be open to any suggestions.
Suggestions that havent worked
1. Dawn dish soap
2. Rubbing alcohol
3.
Paint thinner
4. Using TSP first and then stripper
5. Combining TSP and Zep stripper in single solution
6. Hot water
7. Repeated treatment of ZEP. After 3 cycles the yellow stain does not lighten any further
Suggestions that were somewhat useful
1. "Trewax" stripper. Yellow stain was less, but required more repititions to disolve wax prior to TSP treatment. I've tried using it as an intermediate step between the Zep and TSP and didn't think it made a significant difference.
2. "LA Awesome". house cleaner.
Sold in Dollar stores and some Super market hardware stores. It seemed to be as effective at removing wax as Zep Stripper, but left the same yellow stain.(wax residue) Significantly less expensive than Zep stripper. I decided to continue to use ZEP as it is the "tried and true" approach.
Guesses for why I'm having this rare? Problem.
1. Should have stripped wax when it first showed signs of deterioration. I put it off for about 2 years.
2. Gel coat damaged? Company who will be restoring the shine once Ive gotten the wax off did'nt think the Gel coat was in bad shape, however the trailer is a 2003
3. The trailer had 5 coats of Zep wax
