12 Volt Fridge - Fiberglass RV
Old 11-28-2024, 05:59 PM   #1
Trailer: Trillium 1300 1973
12 Volt Fridge
I'm looking to swap out the ice box in a 73 Trillium and replacing it with a small Fridge, probably a 45 or 65 litre. I am looking at the Bodega brand. Any comments or suggestions on alternatives.
danio is offline   Reply With Quote
Old 11-29-2024, 06:51 AM   #2
I've got 2 12v coolers that I bought when we tent camped. I still use them now with my Casita. I like them because they are very energy efficient and easy to move around. One of them has a divider so you can either have both sides the same, or have one side as a fridge the other as a freezer.
justa25thTA is offline   Reply With Quote
Old 11-29-2024, 08:26 AM   #3
Fridge vs cooler
Thanks for the response Troy. What brand are your coolers?
Old 11-29-2024, 08:34 AM   #4
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-04-2024, 12:19 PM   #5
Alabama
Casita fridge
My 2013 Casita fridge took 3 or 4 days to begin cooling. So, I removed it and use the space for storage. I now use a Bourgerv (59 qt, I believe) frig/freezer. It’s portable and runs on 12 volts. Since I am semi permanently boondocking, I installed a 100 watt solar panel to keep the. Bourge charged. Keeps me from using all my propane waiting for the Dometic to cool. I love the Bourge. It has been flawless. Quick to cool/freeze and very good at maintaining the temperature.
Joemcameron is offline   Reply With Quote
Old 12-04-2024, 12:39 PM   #6
Trailer: Weiscraft
I don't want to take sides over brands, just saying I have used a chest style Engle for at least 10 yrs and recently a front loading model. They run on 12V at 2.3Amp draw and cool down very quickly. Never any kind of problem.
The front loader replaced a 3 way Dometic. If I were to make that change again I would probably use the chest type and build some kind of storage into the old Dometic's space. Why ? Because it was a lot of labor getting the front loader fitted and fastened in place.
regards, Hugh
HVance is offline   Reply With Quote
Old 12-04-2024, 12:39 PM   #7
Trailer: Trillium 13 ft
12V fridge
I put a NovaKool R3800 in my 76 Trillium. You could go smaller. I removed the drawer above the fridge opening to fit, added a little bit of trim around and it works and looks great. I run it off my solar and a 200ha battery.
Kirsten M is offline   Reply With Quote
Old 12-04-2024, 02:10 PM   #8
JPM
Trailer: 1972 Boler 1300
I also use a Bouge RV - 30 quart cooler. I have had no issues with it at all. Very thrifty on power - I leave it plugged into the Pathfinder at all times. It can run over night without draining the car battery. Have a 75 watt solar panel when we are parked for more than a day. Left the ice box in the Boler (1972) and use it for canned drinks etc mainly.
jpm
JPM is offline   Reply With Quote
12 volt dc, fridge
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Michael Pupeza
12 volt versus two 6 volt Nvboatman Electrical | Charging, Systems, Solar and Generators 39 08-14-2018 08:11 PM
Two 6 volt vs. 12 volt deep cycle Kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
Engel MR40F 12 Volt Refrigerator 12 Volt Freezer Mike-N-Laurie Classified Archives 1 04-26-2016 08:05 AM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
