19' Scamp Drill Powered Landing Gear - Fiberglass RV
Old 12-09-2020, 11:00 AM   #1
Hollywood
I have a 1987 19' Scamp.
The landing gear has been replaced and I want to buy another crank to make a drill powered crank.
The diameter of the crank where it meets the landing gear is 3/4" what brand is the gear so I can get the correct fitting?
Is there a cheaper or easier way to make my powered crank.
Tom Johnson
Tcjmiami is offline   Reply With Quote
Old 12-09-2020, 12:04 PM   #2
Trailer: Bigfoot 17G
I find that a nut driver in a battery operated drill works really well.
bobblangley is offline   Reply With Quote
Old 12-09-2020, 12:21 PM   #3
GOB
Trailer: Scamp 19
19 landing gear
I got a piece of 1/2" rod, a 1/2" ID X 3/4OD X 2" bushing. Drill and pin the bushing about 1" on the rod and cut a slot in the end of the bushing. Any 1/2" cordless drill should work. I use a Porter Cable w/2speed switch.
GOB is offline   Reply With Quote
Old 12-09-2020, 02:53 PM   #4
Ditto. My Bigfoot has 4 jacks and a 2nd hand store battery power drill and nut driver do the trick. If I'm boondocking ie w/o 110v for re charging I'll pack a 2nd charged battery. Don't throw away your crank. Poop happens!
I also keep a big piece of cardboard or short length of old carpet to lie down on with jacking up.
burrorojo is offline   Reply With Quote
Old 12-09-2020, 08:32 PM   #5
Steve Hammel's Avatar
Trailer: Casita SD 17
Loon Lake Wa. and Boulder City, Nv.
The best way is to install a 5th wheel landing gear motor. I put one on my Scamp 19 and it worked great.
https://www.ebay.com/itm/Stromberg-C...kAAOSwFGxdaW33
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe.
Old 12-09-2020, 09:18 PM   #6
Raspy's Avatar
Trailer: Black Series HQ19
Smith Valley, Nevada
All you have to do is go to Walmart and find the 3/4" trailer jack nut driver in the RV section, for about 5 bucks. Or go to Amazon. Then get a battery drill and you are done. Riobi from Home Depot makes very cheap and durable kits with the drill, the charger, a battery or two and a soft case. Then drop in a drill index and possibly a Riobi flashlight, and suddenly you can fix all kinds of things and run the jacks at night. BTW, if you use an impact driver, you'll likely twist off the crank pin, or shatter a gear. Just use the drill. There is no need to reinvent the wheel or manufacture anything.
Old 12-12-2020, 03:07 AM   #7
Nevada
I did this. I took a hex shanked 3/8" socket adapter and had my welding guy weld the adapter to a piece of metal rod. Works great off my cordless impact driver.
Except now, the metal rod is stuck.. hahaha
Bfleissner is offline   Reply With Quote
Old 12-17-2020, 06:23 AM   #8
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
https://www.fiberglassrv.com/forums/...1&d=1608207462
Old 12-17-2020, 12:12 PM   #9
Trailer: 2008 Casita 17 SD
Originally Posted by mszabo View Post
Fine for some jacks, but the majority of scissor jacks made require a 3/4" hex head wrench or socket to run them up and down. The 'T" slot fitting one doesn't work on most of them.
Old 12-17-2020, 02:00 PM   #10
mszabo's Avatar
Greg, I thought he was looking for the wrench that fits the landing gearbox
Old 12-18-2020, 12:18 AM   #11
Nevada
While the Scamp19 has stabilizers built into the rear bumper, I installed sissor jacks, which will steady the camper much better. And I use the same drill, with another hex shanked 3/8 inch socket adapter and a spark plug socket to 'speed' lower and raise the jacks.
Replacing 5th Wheel Front Landing Gear brettrae Problem Solving | Owners Helping Owners 10 12-12-2020 02:51 PM
Scamp 5th wheel landing gear idea George n Mary Modifications, Alterations and Updates 3 07-14-2020 01:49 PM
Convert landing gear to electric on Scamp 5er Steve Hammel Problem Solving | Owners Helping Owners 11 09-12-2013 05:56 PM
19 ft 5er Scamp - add electric motor to landing gear? shooter_41 Problem Solving | Owners Helping Owners 14 01-04-2013 05:28 PM
Scamp 5th Wheel front landing gear (Friday the 13th was bad) Gail Shook Problem Solving | Owners Helping Owners 8 07-31-2012 04:33 PM
