1979 Trilluim jalousie windows hardware - Fiberglass RV
Old 05-21-2020, 01:11 PM   #1
Trailer: 1979 Triple E Surfside
Hi there,
I am looking for a window hardware - 2 links (pictured) that would attach to the torque bar. Can anyone help with that?
Thank you kindly,
Mlequo
mlequo is offline   Reply With Quote
Old 05-21-2020, 02:08 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Hehr window operator parts
Pelland Enterprises sells these parts. Here is a link to the web page. One of your links is a Hehr torque arm. It appears on this web page. You might have to call the company to get the correct parts.
https://www.pellandent.com/RV-Torque-Window-Parts
Old 05-21-2020, 02:24 PM   #3
Thank you, John,
I tried but they do not seem to have what I am looking for...
Old 05-21-2020, 03:45 PM   #4
I have purchased Hehr window seals from Pelland, but not the parts that you need.
However you need, for example, a "Hehr Torque Arm-Small
Model Number: H008-221" as shown on their web page, then you could go searching elsewhere for that part. For example, I also found that part here:
Hehr window parts, Hehr International parts, RV window parts, Trailer window parts
Vintage Trailer Supply also sells Hehr window hardware. You could contact them.
Old 05-22-2020, 09:36 AM   #5
Trailer: Outback trillium trailer
trillium window hardware
trillium /Outback trailers in Calgary has everything you need for window replacement parts.
Joe at Outback is offline   Reply With Quote
Old 05-22-2020, 10:16 AM   #6
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Good to know you guys are still around Joe, I actually bought a pulldown awning setup from your outfit almost ten years ago. Got a link to a webpage with other hardware etc?
Old 05-22-2020, 10:19 AM   #7
window hardware
Its best to email us direct, as we have so many vintage trillium parts, new and used, we can help you with all your hardware needs, by the way we have being going strong for well over twenty years and are busy as can be with new trailers orders
Old 05-22-2020, 01:13 PM   #8
Hello Joe,
I just sent an email to trilliumtrailers@gmail.com - thank you very much!
Pawel
Old 05-27-2020, 10:51 AM   #9
Originally Posted by mlequo View Post
Hi there,
Thank you kindly,
Mlequo
I still do not have much luck with this. Hopefully Joe will have some, but it does not look promising, so if anyone could point me in the right direction, I would much appreciate that.
I am also looking for the bug net plastic rails that go on the side of a window (see the photos). If anybody could point me at those...
Old 05-24-2023, 01:28 PM   #10
Trailer: 1972 Boler
BC
Jalousie Window Arm Connector
Hello,
Were you able to find that arm connector piece? If so, could you please share where you sourced it from. I went to a metal fabrication shop and they quoted me $500 to have the part made.
Thanks,
Megan
Meganroberts is offline   Reply With Quote
Old 05-24-2023, 04:48 PM   #11
David Tilston's Avatar
Originally Posted by Meganroberts View Post
Hello,
Thanks,
Megan
Megan, Which window do you need it for? Do you just need the flat bar piece, or the rotating rod, or both?
Old 05-24-2023, 05:14 PM   #12
Trailer: 1972 Boler
BC
Hi David,
I am looking for the connector arm piece that has a little nub on the end.
This is a long shot, but I also need the piece that the bar attaches to (not the crank piece, but the other end).
Old 05-24-2023, 08:18 PM   #13
I have several broken windows for Trillium trailers, for parts. But I don't know if they would be interchangeable with Boler windows. The piece that the bar attaches to would likely fit, assuming that they are the same style of Hehr window. I think Trilliums use the Hehr Series 4900 windows. In this series the model number is visible on the sill. If yours are the same, then I can send you that piece. If you give me the full length of the other parts, then I can check for those as well, but the window panes would have to be the same height for that to work.
I should mention that Joe Thoen at Trillium / Outback has lots of old parts for both Trillium and Boler trailers.
https://trilliumtrailers.com/
I sure do give Joe a lot of referrals.
Old 05-25-2023, 10:23 AM   #14
Trailer: 1972 Boler
BC
Hi David,
Wow, thanks for much for your assistance. If you'd like to send me any parts and they don't fit, I can mail them back to you.
I will check out your friends website and reach out via email as well. See images for the measurements of the pieces. The flat arm piece with the nub is 3" but it is difficult to tell from the images.
Feel free to message me on WhatsApp if it's easier 604-401-8822
Thanks,
Megan
Old 05-25-2023, 11:38 AM   #15
Ummm.... Joe is not my friend. He just runs a Trillium manufacturing operation. I'm a Trillium fan.
Please look for the model number of the window.
I don't use WhatsApp, or any other social media, other than this site.
jalousie windows, trillium, windows
Window seals & hardware for 76 Scamp tilt out windows Jenny W. Modifications, Alterations and Updates 47 04-21-2021 10:45 PM
I can't get the furnace going again - 1976 trilluim thimith Problem Solving | Owners Helping Owners 13 09-15-2018 01:01 PM
SOLD 1975 trilluim 13 ft. $ 4300.00 piersons Classified Archives 6 04-15-2014 06:34 PM
Pizza Pop Commerical with a Trilluim 5500 Kenny H General Chat 0 11-18-2008 04:22 PM
