06-13-2018, 09:11 AM
#41
Trailer: Sprinter 'til I buy
Denver, CO
I believe the group has made it abundantly clear that many prefer twin tanks, so I won't beat a dead horse or Amy. You all know they sell trailers with just one tank, right? I'm sure everyone has your best interests at heart, and even if I had your cool batteries, ....well never mind.
I would look for the supporting tray in a single tank version at a dealer with some old stick builts ready to become organ donors. But I would also price new ones on-line, as a used one may require sanding and paint.
Good luck, Amy
06-13-2018, 09:12 AM
#42
Trailer: 2008 Casita 17' SD
I doubt that you will notice any difference in towing/handling whether you have one tank or two tanks installed. The weight in the propane tank bracket is pretty well set up transverse to the "A" frame on the front of the trailer. You'd probably have more of a weight differential just based on how and where they installed the major appliances and tanks in your trailer than this would ever amount to.
06-13-2018, 09:20 AM
#43
Trailer: scamp 13
ME
Ok, thank you! I will take the tray off and see if I can just put the single tank there if not I will just set it up as 2 tanks and leave the other one off
Thanks!
06-13-2018, 09:30 AM
#44
Trailer: scamp 13
ME
Good luck, Amy
I am sure if I have a shower hookup I probably do need 2 tanks, but at this moment I only use it for a fridge. So even this huge propane tank (one) is way too much for me. I didn't realize you can fill it at truck stops either so if that's the case I can even go without filling it all the way just half every time and won't need to worry about looking for places to fill it up
Thank you all for replying! I'll see what I can do this weekend and convert it accordingly!
06-13-2018, 10:22 AM
#45
Great answer, Tom. One tank or two- depends on how you use propane. One tank lasts us about two seasons. A second would be 45 pounds of useless weight. We have plenty of tongue weight with one tank.
I'm actually thinking about Casita Greg's set-up, but keeping the current single-tank regulator. One small tank connected to the trailer to fuel the furnace and the other removed at camp to fuel our outdoor cooking appliances. They're just so doggone expensive!
06-13-2018, 12:13 PM
#46
Originally Posted by Jon in AZ
I'm actually thinking about Casita Greg's set-up, but keeping a single-tank regulator. One small tank to fuel the trailer and the other to fuel our outdoor cooking appliances. They're just so expensive!
On that issue I fully agree. They charge more than double for those half-sized 2.5 gallon tanks as they do for the common 5 gallon ones. I guess it's because they sell a lot more of the 5 gallon variety than the half-sized ones. But, having bit the bullet on their cost, I really do have to say that they are great in reducing the weight. I am not a big user of propane, (I filled these tanks 3 years ago and I still have yet to turn them on for anything other than for a system function check.) Since we usually camp with full hook-ups, I can count the times on one hand (with fingers left over,) in the 10 years that I have had the trailer, that I have "boondocked", but I still wanted to keep the ability to use it just in case.
As to outside cooking, which for us, is 99% of our cooking, I bring along a 5 gallon lightweight composite tank that I just set up out near our portable Camp Chef stove by the picnic table.
06-14-2018, 03:59 PM
#49
Trailer: scamp 13
ME
Originally Posted by John in Santa Cruz
Ok, wonderful, thank you! ❤️
06-14-2018, 04:26 PM
#50
Check a little further.. I cant find any specs on the regulator, and it appears to be single stage... unless I missed something in the thread, I have questions about this recommendation. And don't bother reading the Q&A section on Amazon.. those people are mostly clueless on this topic.
Read this: https://rvshare.com/blog/rv-propane-regulator/
06-14-2018, 04:34 PM
#51
Originally Posted by floyd
Switching to a single regulator($32) is a small and inexpensive matter, and you may be able to sell your doubles or store the kit complete for future use......
I could not help but notice that the regulator in this photo is mounted with the vent horizontal.
When my regulator, which was mounted the same way, failed (after less than 1/5th of its expected lifetime), I read the instructions and found this is wrong. Water needs to be able to drain out, or a cover is needed (or both).
Perhaps OP should bit the bullet and go to a RV shop for this mod (or just leave one tank empty). Propane is something you don't want to do wrong (even if Evelands does mount the reg improperly sometimes).
06-14-2018, 04:50 PM
#52
Trailer: scamp 13
ME
Haaa...now you're scaring me...
Ok, I'll just leave it as is and take out the 1 propane. It'll only be for this summer anyway
06-14-2018, 04:57 PM
#53
There is something to be said for:
Kiss.... Keep It Simple Sally!
PS, I just noticed the blog I linked to was written by another Amy. Funny coincidence.
06-14-2018, 05:00 PM
#54
Trailer: scamp 13
ME
Hahaha!! Will do!
I think I'll buy a cover though that article says to buy it ASAP and it's only $25 on Amazon! Thank you!
06-14-2018, 05:05 PM
#55
Mid Left Coast
I would unscrew the hose to the 'missing' tank, and put a plug in, using propane friendly sealing tape (usually yellow, instead of the white teflon tape used for water connections).
06-14-2018, 05:15 PM
#57
I have my doubts that a cover is critical as long as the vent faces down (within 45 degrees). But it sure wont hurt.
But $25 is way high.
Just get one that fits, or can be returned if by chance it does not.
06-14-2018, 05:19 PM
#58
Denver, CO
Some may know better, but I agree with the idea of leaving the empty tank there for this summer, or removing it and plug or cap the hose. K.I.S.S.
06-14-2018, 05:50 PM
#59
Mid Left Coast
yes on the tape, you can get that at any hardware store, no on the cap, that one is for a 1 lb 'coleman' style propane bottle such as are used on camp stoves.
the hose fitting coming out of the change-over valve is /probably/ 3/8" NPT, if it is, then use something like this... https://www.amazon.com/Anderson-Meta.../dp/B0045LRZP8
again, I would get this at a local 'real' hardware store (avoid the big box home depot kinda places).
06-14-2018, 05:55 PM
#60
Trailer: scamp 13
ME
Ok!
Thank you so much everybody, so very nice of you all, it helped tremendously! I can now enjoy my camping this summer without any worries
