3M Foam fast 74 - Lauan panel to foam - Fiberglass RV
Old 05-17-2022, 07:14 PM   #1
Trailer: Alaskan Camper
I'm wondering if this product would be suitable gluing paneling to foam insulation. I've heard of people using Spray 77 - I just tested it on some foam and it melted it. Just stumbled on 3m foam fast, wondering if anyone has experience with it.
I also have low VOC contact cement which I've haven't had great results with, maybe its still too cold out here, may have more success with it if it ever warms up here.
Eldonderino is offline   Reply With Quote
Old 05-17-2022, 09:11 PM   #2
David B.'s Avatar
Contact 3M and they will help you with the proper product.
Old 05-18-2022, 01:08 AM   #3
John in Santa Cruz's Avatar
Mid Left Coast
I think it's spray 77 that we used to use to secure the hood pads under the hood of a Mercedes. You sprayed it on the clean metal Hood underside, you spray it on the foam, you let both sides dry, spray a quick dusting on the foam and then boom and stick on contact. You have to get it positioned exactly right the first time cuz you don't get a second chance
Old 05-18-2022, 08:10 AM   #4
thank you. I'll have to contact 3M and get the story straight. I read, on a airplane modelling forum, that they change the formulation of spray 77 so it no longer works with foam, not sure if that's true or not.
Old 05-18-2022, 11:39 PM   #5
Mid Left Coast
There are different sorts of foam, too what dissolves a polystyrene foam might not affect a neoprene or urethane foam.
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
Hi: I need fast answer on cost of black tank/line freeze damage repair Janine Plumbing | Systems and Fixtures 5 10-14-2007 07:47 PM
Lightweights in fast lane at RV trade show Patrick M. General Chat 3 11-30-2006 01:34 PM
Fast Eddie james kent General Chat 3 04-17-2006 08:15 PM
Winter is coming fast. Legacy Posts Problem Solving | Owners Helping Owners 10 11-19-2002 07:53 AM
