5th wheel newbie - Fiberglass RV
Old 06-09-2017, 04:57 PM   #1
Trailer: ESCAPE 5.0TA
Cool 5th wheel newbie
I just took my new Escape 5.0 TA for its first trip out. I am towing it with a 2007 Nissan Frontier crew cab and have noticed what someone told me was "chucking"
This is rather annoying and I'm hoping someone with a Nissan Frontier and escape 5.0 combination can tell me if this is common. The trailer is brand new and the truck is in good shape for a truck with 100KAny help will be appreciated.
Thanks
THIBODEAUX is offline   Reply With Quote
Old 06-09-2017, 05:49 PM   #2
Trailer: Escape 5.0 TA
W. Mass
Chucking is caused by the hitch, what kind of hitch do you have?
Bob & Deb
padlin00 is offline   Reply With Quote
Old 06-09-2017, 06:03 PM   #3
It is a Reese 15 K. I bought it from Escape when I bought the trailer
GJT
Old 06-09-2017, 08:11 PM   #4
Greg have you posted your concerns on the EscapeForum? You'd probably get more information/help there as most Escape owners are there.
Old 06-09-2017, 08:34 PM   #5
Thanks
I had thought about that but had a hard time signing on to their web site
I'll try again
GJT
Old 06-10-2017, 04:07 AM   #6
W. Mass
Might talk to the folks that installed the hitch. Chucking is play between the king pin and the jaws or slide bar in the hitch, felt as bucking in the truck, should be none or very little. I suppose in a small truck like the Frontier you would feel it more then a full size. I'd do like Donna suggests and post this over on the Escape forum.
Bob & Deb
Old 06-10-2017, 07:27 AM   #7
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
A couple of observations. I have a Scamp 19Deluxe and pull it with a 2013 Tacoma, so it is quite similar. When I towed it home the very first time (first 500 miles towing anything in my life), I was very nervous about what I would also describe as chucking. I did all kinds of research on hitches and found many different solutions. However, the problem went away after I increased the pressure to the Scamp suggested 45 psi, instead of 32 to 35 which I towed with then, being uneducated and thinking in terms of car tire pressure. So try to pump up the tires to the allowed maximum for your next trip.
All those "soft" hitches seemed to be complicated and expensive, so they were not going to be my first attempt at solving the problem anyway. There is a hint of it, but no big deal.
This kind of rig does have that tendency, it might be less noticeable with a heavier truck. Also, there are some highways and interstates that have a wave built in that makes this quite unpleasant. They are usually those concrete new ones. I wonder what is wrong with those concrete finishing machines.
Old 06-10-2017, 07:50 AM   #8
I have an Escape 5.0TA and the same hitch as Greg. There's no slop, but it's far from quiet when towing on rough roads. I think a lot of that has to do with the fact it's a lot closer to my ears than a bumper pull so I'm more aware of noises.
Greg, since someone told you it was called chucking, how did you describe it to that person so they were able to give you that definition?
One of the solutions I read on the Good Sam Open Road forum says there's not enough weight on the the pin. Were the rear tanks full? Bike rack and bicycles? Maybe move stuff around inside...
Old 06-10-2017, 10:13 AM   #9
Trailer: Escape Trailers
Massachusetts
We had that combo
One of the solutions I read on the Good Sam Open Road forum says there's not enough weight on the pin. Were the rear tanks full? Bike rack and bicycles? Maybe move stuff around inside...
We pulled a 5.0TA for a couple years with a 2007 Frontier 6cyl, 2wd, crewcab, 6' bed, using a Reese 15k hitch, and had no problems. Alf, on the Escape site, has a newer Frontier and has pulled first a 5.0 and then one of the earliest 5.0TAs. He has a different hitch and is quite happy with the setup.
I agree with Donna that you may not have enough weight on the kingpin, it should be around 15% on the total trailer weight. You don't want too much on the pin as it's easy to exceed the Frontier's recommended payload.
Good luck with finding a solution,
David
Stretcher is offline   Reply With Quote
Old 06-10-2017, 08:08 PM   #10
Alf S.'s Avatar
Originally Posted by THIBODEAUX View Post
Thanks
I'll try again
Hi: THIBODEAUX... The 5.0TA is a well balanced trailer. I found If you tow with a full tank of fresh water you will take weight off the pin. This will make the chucking sensation worse. Our Frontier is used only for towing so I add 5#'s extra pressure to the trucks rear tires and also max pressure in the trailer tires. Our combo is level when hooked up. Our hitch is a Husky 16K EZRoller slider hitch but we don't need to slide it!!! Tammy's dad at ETI lowered the hitch plate 1 set of bolt holes to make it level.
escape
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
Newbie blindly buying Scamp 5th Leland, LeBaron Care and Feeding of Molded Fiberglass Trailers 16 12-01-2009 02:56 PM
Like new Scamp 5th Wheel loft Bed Pat And Arleen Classified Archives 0 12-11-2005 02:33 PM
SCAMP 5TH WHEEL?? Dan Quinn General Chat 11 12-07-2005 11:01 AM
