77 boler windows - Fiberglass RV
Old 05-31-2021, 07:25 AM   #1
Trailer: 13' 1977 boler
77 boler windows
Hi all, my daughter just purchased a 13' 77 boler. It has been gutted. They left the support sections in which is great, but looks like they removed the fromt and back windows with a jack hammer. Alot of cracked fibreglass around the frame and the radius corners are pretty much non existant. My question is does anyone know the dimensions and the radius of these windows? Want to go back to original boler windows but want to make sure that the repaired fibreglass gives us the proper size cut out so the gasket and window fit properly. Thanks!!
MattRMX is offline   Reply With Quote
Old 05-31-2021, 09:57 AM   #2
Phil Underwood's Avatar
Trailer: Tri Fab
Odem,Texas
when my brother restored his boler, he pretty much had the same problem.
He repaired the fiberglass and then had the glass company cut to fit a plexiglass window.. it was cheap and worked fine
Phil & Denise Underwood
1973 13ft Lovebug
2001 Dynamax
Phil Underwood is offline   Reply With Quote
Old 05-31-2021, 10:17 AM   #3
Thanks Phil! Did he end up just using a automotive gasket to seal it up?
Old 05-31-2021, 11:32 AM   #4
Trailer: Tri Fab
Odem,Texas
they cut the plexiglass and used a gasket and sealed it with windshield adhesive.
1973 13ft Lovebug
2001 Dynamax
Old 05-31-2021, 11:33 AM   #5
Trailer: Tri Fab
Odem,Texas
here ya go
https://www.fiberglassrv.com/forums/...ome-42567.html
1973 13ft Lovebug
2001 Dynamax
Old 05-31-2021, 12:23 PM   #6
Cheers!!
Old 05-31-2021, 01:06 PM   #7
Trailer: Tri Fab
Odem,Texas
Originally Posted by MattRMX View Post
Cheers!!
Lets see some photos of your Boler
1973 13ft Lovebug
2001 Dynamax
Old 05-31-2021, 01:24 PM   #8
Just posted some pics of the unseen fibreglass damage on the floor and wheel well in the fibreglass forum. Completely stripped done now other than the mess in the corner that they tried to hide. Here's a few shots, hoping to be able to remove all the junk in the corner and repair properly. They screwed metal brackets covered them in fibreglass then body fill, what a mess.
Old 06-01-2021, 03:53 AM   #9
Trailer: Tri Fab
Odem,Texas
looks to have a new axle underneath.. any idea what type it is?
1973 13ft Lovebug
2001 Dynamax
Old 06-01-2021, 10:35 AM   #10
Replaced a few years ago seller said, assuming the old snapped and thats why all the wheel well damage. Towed really well, but going to replace hubs and wheels anyway.
Old 06-01-2021, 12:25 PM   #11
Trailer: Tri Fab
Odem,Texas
good call on the hubs.. i enjoy getting to see the photos.. please post any of your progress / upgrades along the way
1973 13ft Lovebug
2001 Dynamax
Old 06-06-2021, 06:47 AM   #12
Hi, I also have a 77 Boler. I replaced both the front and back windows. Everything you need to know is on this site -
https://www.boler-camping.com/boler-...-rear-windows/
As far as replacing the Plexiglas you can use Lexan or plexi. I ended up with one of each because that's what they had in stock at the time. I put the Lexan in the front window for strength against rock chips and the plexi in the rear. I gave the glass dealer my old window to use as template for them to cut out the new.
The only problem I had was the factory window cutout in the front was a little off and really the window should have been a little larger to fill in the gap better. I almost wish I had just measured the opening instead of using the window as template. But it does not leak so I don't worry about it.
It was a little difficult to get the windows in. I recommend 2 people.
Yellow Boler is offline   Reply With Quote
Old 06-06-2021, 09:45 AM   #13
Originally Posted by Phil Underwood View Post
Now you got me interested. That was a neat idea to install the ac out the fridge vent. How did that work? Also, where did you install the fridge? Any pics of that?
Old 06-06-2021, 04:27 PM   #14
Borden's Avatar
Name: Borden and Carole
Like looking at your repairs Phil, looks good
Our postage stamp in heaven.
Old 06-07-2021, 02:02 PM   #15
Trailer: Tri Fab
Odem,Texas
Sadly we never got to install a fridge, a guy stopped buy and offered 5k for the boler and we sold it to him, my brother only took the boler out on 2 trips before he sold it..
1973 13ft Lovebug
2001 Dynamax
boler, windows
To pull out my windows or not pull out my windows??? Alyson Brown Care and Feeding of Molded Fiberglass Trailers 15 04-30-2017 07:24 AM
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
