86 B17 Bigfoot rock guard arm? - Fiberglass RV
Old 08-13-2020, 09:50 PM   #1
Trailer: 17ft Bigfoot trailer
Hello all,
Iím hoping to locate a replacement rock guard arm for my 1986 17ft Bigfoot, but having no luck. I contacted Bigfoot (Armstrong, BC) and was informed they no longer have this part in stock and suggested that a newer gas strut may be too strong for the rock guard. Any leads on where I may be able to track down this assembly would be greatly appreciated.
Thanks,
Michael
Bluebamboo is offline   Reply With Quote
Old 08-13-2020, 10:34 PM   #2
When I had my 94 Bigfoot, it had gas struts that were worn out. I ordered new ones from Ebay. Your earlier model had a different mechanical system, but I'm sure gas struts could adapted to your rock guard. Maybe someone with a later model can give you some measurements or catalog numbers. I'm pretty sure your rock guard is slightly larger than the later guards. Best of luck.
Old 08-13-2020, 10:41 PM   #3
Thanks for the reply, Jack. I’ll check them out ��
Old 08-14-2020, 08:08 AM   #4
ZachO's Avatar
Trailer: Sasquatch
Montana
Do you have photos/measurements for your arm? I have a 91 with gas struts. Maybe they’re similar.
Old 08-14-2020, 10:24 AM   #5
Trailer: Parkliner
Do you have the sliding type rockguard arms? Vintage RV Supply used to have ones meant for Airstreams. I am not sure if they have them in stock right now but I would check with them.
Annie Snyder
2011 15' ParkLiner
AnnieSnyder is offline   Reply With Quote
Old 08-14-2020, 12:22 PM   #6
Originally Posted by ZachO View Post
Do you have photos/measurements for your arm? I have a 91 with gas struts. Maybe theyíre similar.
I think 91 was the first year for gas struts.
Old 08-14-2020, 04:48 PM   #7
Hi Zach,
Thanks for the reply. I’m thinking of dropping by a local RV shop to see if the gas struts could be adapted.
Michael
Old 08-14-2020, 04:51 PM   #8
Hi Annie,
Yes, those are the ones! I’ll check out Vintage RV Supply. Thank you.
Michael
Old 08-14-2020, 05:12 PM   #9
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Check these at Vintage Trailer Supply:
https://vintagetrailersupply.com/sto...t-arm-vts-808/
Old 08-14-2020, 05:24 PM   #10
Those are what holds up my Escape rock guard. I like that they can be opened to any position and locked there. I usually have the rock guard open enough that I can see out, but hard to see in.
Old 08-14-2020, 05:50 PM   #11
Hi John,
Yep, I think those will work. Looks like they’re out of stock presently. I’ll definitely pick them up when they get some. Thanks for posting the link.
Michael
Old 08-14-2020, 05:51 PM   #12
Nice looking set up, Glen. Always liked the Escapes!
Old 08-14-2020, 07:51 PM   #13
Trailer: 1987 Bigfoot B-17'
I have one of those, but sadly no stone guard anymore. Youíre welcome to it.
Message me. Rteagardin@comcast.net
Iím near Seattle.
Robert Teagardin
Glass House is offline   Reply With Quote
bigfoot
Leading Arm or Trailing Arm Bill Nolen Towing, Hitching, Axles and Running Gear 43 02-05-2016 01:06 PM
Opaque rock (gravel) guard on Bigfoot trainjunkie Modifications, Alterations and Updates 10 12-27-2013 01:41 PM
Bigfoot addtional rock guard support Tim D. Modifications, Alterations and Updates 3 04-18-2011 05:32 PM
Replacing an Axle - leading arm to trailing arm Roy in TO Modifications, Alterations and Updates 38 11-21-2010 02:00 AM
rock guard 17 ft. bigfoot bob11105 Problem Solving | Owners Helping Owners 0 09-08-2009 08:05 AM
