86 Playmor II - Fiberglass RV
Old 01-02-2019, 04:36 PM   #1
Trailer: Playmor
Wisconsin
86 Playmor II
Iím looking for a front window for a 86 Playmor fiberglass camper, and possibly a water tank. I donít know where to find these items as Playmor doesnít have any.
Letsgotothecabin is offline   Reply With Quote
Old 01-03-2019, 12:21 PM   #2
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
You should find a good replacement window from Hehr, or possibly Sunsetter. They both have a pretty wide selection of styles and sizes. Playmor undoubtedly used a standard model from an RV window manufacturer and these are the only two I know.
Walt
Old 01-03-2019, 12:54 PM   #3
WHICH model of the Play-MOR? The larger one which looks like a square boler or Amerigo and needs a wide Jalousie window? Or the 13' that looks like a boler or Scamp and needs a plexiglass window?
Old 01-03-2019, 03:19 PM   #4
Trailer: 2013 Escape 19
On water tank, Amazon sells hundreds of them. Just measure the size of your space and pick one out. This is what I will do eventually on my 1977 Trillium. IMO, there is no need to get an "exact" replacement.
Old 01-03-2019, 03:32 PM   #5
Trailer: Playmor
Wisconsin
Thanks for all the information. I will try to find a window following your ideas, I have a Playmor II. Itís small, I think 13 feet including the hitch. The plastic water tank is inside the closet so Iím thinking it has a leak but itís cold here in Wisconsin and itís snowed a lot. Just bought it as is.
Old 01-03-2019, 03:33 PM   #6
Trailer: Playmor
Wisconsin
Itís a plexiglass window for sure.
Old 01-03-2019, 04:27 PM   #7
David B.'s Avatar
You should be able to have any auto windshield shop make one up for you, and have them replace the rubber at the same time.
Dave & Paula
Old 01-16-2019, 12:37 PM   #8
Trailer: 1986 Play-Mor II & Scamp 13' Build date April 2019
Connecticut
Yes it is Plex. I need to replace mine also
CSiko is offline   Reply With Quote
Old 01-17-2019, 12:46 PM   #9
Trailer: Play-Mor 11
My 86 PlayMor Windows
My 86 PlayMor has Jalousie windows all the way around. I need to replace gaskets (plastic trim pieces) on the individual louvers of the windows. There are so many types of these - does anyone know which type fits these windows. I know it is sometimes hard to find the right one.
Love my PlayMor. Pulls like a dream.
carlotlizard is offline   Reply With Quote
Old 01-18-2019, 09:52 AM   #10
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Eddie, try this site:
https://www.vintagetrailergaskets.com/
Old 01-18-2019, 12:13 PM   #11
I am aware of this site and they have several types. I was just hoping someone knew the exact ones without my taking windows out before ordering. Probably that is what I will have to do. Thanks for your reply.
Old 01-18-2019, 12:54 PM   #12
Alex Adams's Avatar
New Hampshire
Eddie, that is hard to do. The windows on these trailers could change depending upon what was available to use when the trailer was being built. When I finally tracked down some of the seals for my trailer I found that my Hehr Jalousie windows used some different seals than someone else's exact same model year, make and model of trailer. I would recommend looking at what is on your trailer and compare it to any diagrams showing on the website. One other thing you could do is to look for the model number of the window. It should be stamped somewhere on the frame. Keep in mind you may have to remove trim to find it. Another thing you could do is either order an existing sampler pack of seals that are offered or ask if you could purchase small pieces of the seals so you can verify they are correct.
playmor 2 interior head height? Mcmarkrazz General Chat 1 08-17-2013 07:48 AM
Playmor Chillywilly Referrals: Molded Fiberglass Trailers 1 06-27-2013 05:39 AM
1986 Playmor II 13FT Like a scamp So Cal $3900.00 Cindy Ross Classified Archives 3 07-14-2010 05:28 PM
1987 Playmor 10ft $4500 Robin G Referrals: Molded Fiberglass Trailers 1 02-26-2010 06:38 AM
