93 Scamp Heater - Doesn't Come On - Fiberglass RV
Old 06-06-2020, 03:53 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
We are out camping & last night got chilly.
Propane is full.. stove lights but I hear no usual clicks in heater when thermostat is turned up.
Any ideas on what to check?
Thank you
barryra is offline   Reply With Quote
Old 06-06-2020, 04:04 PM   #2
If its a Suburban furnace, check for matching model number on cover page. If found, the trouble shooting flow charts start on page 27.
http://www.bdub.net/manuals/Suburban_Service_Manual.pdf
Old 06-06-2020, 08:21 PM   #3
barryra's Avatar
Thanks... I'll read that when we get to our PC. Hard to read on phone.
I can hear nothing? Nothing happens.... would it be a fuse somewhere?
It is a Suburban brand.
Old 06-06-2020, 08:48 PM   #4
IllAnnoy
It is common for the thermostat to stick.
Slide it back and forth a few times, if the fan starts , be patient, the fire may start after about 30 seconds.
If it doesn't start, slap the side of the furnace because it may have a sticky sail switch.
If that doesn't do it check the in and out air tubes for obstructions...Dirt daubers just LOVE to build nests in there.
After all that, go to the troubleshoot procedure
Old 06-07-2020, 04:37 PM   #5
Trailer: Casita SD
furnace
Hi,
If you are on shore power and furnace doesn't start it is probably your battery. Check fuse first.
Judy
Judy M is offline   Reply With Quote
Old 06-07-2020, 04:38 PM   #6
Trailer: Casita SD
furnace
Oh, I should say this happened to me and it was the battery.
Judy
Old 06-08-2020, 08:57 AM   #7
ZachO's Avatar
Trailer: Sasquatch
Montana
If by "no click" you mean at the thermostat, then it's a thermostat problem. Depends on which click you're referencing.
The trouble shooting guide for my Atwood is surprisingly good. It takes you through what's necessary for everything to function, as it happens in the furnace system, step by step. It makes it fairly easy to isolate the problem.
No thermostat click means the thermostat isn't functioning. Thermostat working, no fan can be fuses or relays. Fan turning on but heat not firing means the sail switch isn't closing, either because there isn't enough battery power to get the fan up to speed to blow it closed, or because the switch itself is failing.
That's as far as my knowledge goes. I've never had to trouble shoot the gas components.
Old 06-08-2020, 10:40 AM   #8
barryra's Avatar
This is kinda weird... I turned thermostat up & nothing happened.
I forgot to turn it back to off.... about 2 hours later my wife wakes me up asking what the clicking sound was.... I then could smell the heater was on... & there was heat!
Any ideas?
Old 06-08-2020, 11:02 AM   #9
If there is a plate on the fire box that you can open, Do so and see if the fire box has water in it. If it does, remove the water and dry the inside of the fire box, reassemble and try to lite.
Wagon Master heater temp control doesn't shut off burner. PumpkinBoler Problem Solving | Owners Helping Owners 4 06-11-2017 02:14 PM
Wagon Master heater temp control doesn't shut off burner. PumpkinBoler Problem Solving | Owners Helping Owners 0 09-21-2014 04:43 PM
Doesn't look like a scamp???? Cricket General Chat 12 10-22-2012 09:06 AM
finding A part for my Scamp (that Scamp doesn't make any more) James R Williams General Chat 12 01-24-2011 05:53 AM
How do you guys make sure that your hitch doesn't come off.... kentj Towing, Hitching, Axles and Running Gear 11 05-27-2008 08:13 PM
