A "Shady" Situation Needs Your Advice! - Fiberglass RV
Old 06-16-2021, 09:49 AM   #1
Bob Dunn's Avatar
Trailer: 17 ft Casita Spirit Deluxe
Our 2004 Casita Spirit Deluxe has been sitting in its carport for w-a-y too long and I'm the process of getting 'er running again. Apparently even though the trailer was shaded, sunlight seems to have broken down the plastic on the awning endcaps. I've searched online to match the apparent model number, but with no luck. An email to Dometic (did they make the Horizon awning or not?) has produced no results.
Any thoughts on getting the right caps? Are they tough to change?
2004 Casita Spirit Deluxe • 2009 Ford F-150 STX
Amateur Radio K5IQ
Bob Dunn is offline   Reply With Quote
Old 06-17-2021, 01:20 PM   #2
Trailer: Casita 16 ft
A good project for someone with a 3D printer.
Friz is offline   Reply With Quote
Old 06-17-2021, 01:53 PM   #3
Bob Dunn's Avatar
Thanks, Friz! That's a good suggestion (if I had dimensions) because there's a "fab lab" down the hall from my office. Meanwhile, I learned that the awning was made by Fiamma and they MAY have parts. I have an email into them, awaiting a reply.
Amateur Radio K5IQ
Old 06-17-2021, 06:30 PM   #4
When you get the new part be sure to paint it with something like the Rustoleum plastic paint. It will block the UV and extend the life.
Back when I actually worked I had the maintenance people paint the plastic pipe and rubber fittings with a quality latex paint to help extend the life of those parts as well.
Old 06-18-2021, 11:41 AM   #5
Trailer: 2013 Escape 19
Big fan of krylon fusion paint, sticks to plastic very well and protects from UV attack.
Old 06-18-2021, 11:50 AM   #6
Yeah, That is what I meant.
Old 06-23-2021, 10:29 AM   #7
Dometic does not make anything. They just put there name on other's work.
Extend your awning and look carefully at the back aluminum frame and you'll find two tags. On my 1999 Casita the tags were over the door. Look for the Fiamma tag and get their model number. Then go here and find the part number(s) and order your parts online.
https://www.fiammausa.com/en/fiammas...ings-453977285
You may want to order both ends. That number you show on the tag is for the tag.
Old 06-23-2021, 02:42 PM   #8
Trailer: "In the market"
South Carolina
Gel coat
I had the same issue with my awning caps. I used some left over white gel coat. Brushed on about 3 coats. Looks good and bullet proof
tarpkir is offline   Reply With Quote
Old 06-27-2021, 01:57 AM   #9
Motoboss's Avatar
Trailer: 2001 Casita 17' SD
IN
Try here
https://pantherrvproducts.com/awnings/fiamma-parts/
https://pantherrvproducts.com/02741-01/
"Adventure Before Dementia"
2001 Casita Sprit Deluxe 17
2019 F150 4x4
Motoboss is offline   Reply With Quote
Advice installing Shady Boy Awning on Burro Tommy Gun Modifications, Alterations and Updates 14 07-27-2016 11:50 AM
"customized"scamp ultralite-shady cove, OR Greg A Classified Archives 10 01-31-2009 06:15 PM
Sticky Situation Clint Care and Feeding of Molded Fiberglass Trailers 4 08-03-2006 10:23 AM
