AC unit dilemma - Fiberglass RV
Old 04-09-2020, 04:50 PM   #1
Lake Worth
AC unit dilemma
Hello, everyone! I have been doing some research on AC units for my 13 ft 1988 Scamp, and I have narrowed it down to two style options: Dometic Penguin II Low Profile Roof AC unit and the Dometic Cool Cat closet AC unit. Does anyone have these AC units? Are the low profile rooftop AC units better than closet units? Are there any other units that are similar to these but cheaper? I would love to hear the pros and cons about what you guys have!
annalisewellman is offline   Reply With Quote
Old 04-09-2020, 05:37 PM   #2
AC0GV's Avatar
Wisconsin
Statement from Scamp
Q. Can roof air conditioners be added to older Scamp trailers? A. Thirteen foot Scamp trailers donít have the roof air support unless there is already a roof air installed or if the original buyer requested that the trailer be built that way. Also most trailers with a power vent in the roof air spot wonít have supported roofs. Most 16 and 13 foot trailers prior to 2000 used a side air conditioner in the lower part of the closet by the door. This air conditioner is no longer available.
Old 04-10-2020, 09:00 AM   #3
At one time Scamp installed roof AC in older units by adding wood braces spanning the raised trolley section of the ceiling on either side of the AC unit. Iíve seen a couple done that way by Scamp.
Itís a bit more work, but you could add the fiberglass reinforcement yourself by carefully cutting and peeling back the lining in the center of the ceiling, glassing in 1-2 layers of fiberglass mat, cutting the AC opening, running the wire, and reattaching the lining.
Cabinet mount is not as efficient and steals valuable storage, but it can be done. You have to cut a rather unsightly vent in the shell, and getting the baffling right is tricky. You must also provide for drainage of condensation.
Old 04-10-2020, 09:02 AM   #4
+10 Jon's idea. More work, but once it is done, you will be glad to have it there.
Old 04-10-2020, 09:46 AM   #5
GlenDReed's Avatar
Trailer: Scamp 13' 2016
I have the roof air in my 2016 13' Scamp. It is too loud. I can only use it in extreme conditions. I bought noise cancelling ear phones especially for this. However it does a great job of cooling, to the point of being overkill.
GlenDReed is offline   Reply With Quote
Old 04-10-2020, 02:18 PM   #6
Raspy's Avatar
Trailer: Black Series HQ19
Smith Valley, Nevada
It seems the Cool Cat is about the same price as the Dometic Penguin 2 roof unit. I had a Dometic Penguin 2 in my Oliver and hated it. Extremely loud and blowing right on the bed.
You could get a house type window unit from a big box store, for 1/3 the price, and configure your cabinet to accept it. I would be a lot quieter and you could pick a smaller unit that would run easily on a small generator. The power would be easier to run to the cabinet, than to the ceiling, and the condensate could simply drip out with a short piece of rubber hose, as compared to running a tube down from the ceiling, or having it just drool down the side. And you would avoid trying to reinforce the ceiling in a way that was both strong enough and did not take away too much headroom. The cabinet work would take some thought, but the window units already come with a decorative front control panel, so the only work would be to mount it and separate the in and out cooling air from behind. And install one or two appropriate size grills to the outside. You might get those down to two 6" round vents. With a roof unit, you would be adding 100 lbs to the top of the trailer where it is least desirable to add it.
Also, look at how Snoozy did their AC units. That is another possibility.
If my Oliver would not have come with roof AC, I might have installed one in a cabinet and not had the noise, or the hulk on the roof, which would have also made more room for solar. I looked at it carefully, but it wasn't worth the change from what was already there.
Old 04-10-2020, 08:32 PM   #7
Lake Worth
Thank you so much, I am going to take your advice.
Old 04-11-2020, 06:38 AM   #8
One thing I can vouch for, roof air is NOISY!!
As much as I get concerned about water damage from a traditional AC in a closet or gaucho, Casita has been doing this for DECADES. So there is a way to do it right.
Old 04-11-2020, 08:08 AM   #9
AC unit dilemma
Yes, and to me the Casita installation is ugly, with two large vents on the front corner, one for intake and one for exhaust. Both require snap-on vinyl covers to keep water out when towing. There are baffles inside the cabinet to keep the intake and exhaust from mixing and reducing efficiency. Cool air tends to pool on the floor while your head swelters.
There is no simple solution for AC in a thin-walled trailer.
Cabinet mounted window AC is inexpensive, relatively quiet, and can be run off a smaller generator, but it takes some mechanical chops to get the installation right. A low-mounted unit improves NVH but fights convection. A small fan helps to circulate and mix the warm and cool air.
Roof AC is expensive, noisy, and vibrates the whole shell, but itís efficient (better exhaust circulation on the roof and better convection in the cabin) and easier to install (except for that darned fiberglass reinforcement).
Floyd did a clever installation of a window unit through the front shell of an older Scamp. The business end was outside the trailer over the tongue for efficient circulation and less noise. Inside, the warm air intake was under a front dinette table, while the cold air return was high over the table. It made a good-sized hole in the shell, but not so noticeable over the tongue. It is not a beginnerís project and was part of a major remodel of the front sofa area. May have required some rearranging on the tongue, too. Iíll try to find a link later when Iím on my laptop.
Old 04-16-2020, 01:54 PM   #10
Steven Tonnesen's Avatar
Trailer: 1984 U-Haul 13 ft
Send a message via Yahoo to Steven Tonnesen
Very inexpensive options are available
A few years ago, I had a Scamp 16 in which someone had incorrectly installed an inexpensive, ordinary small window air conditioner in the lower part of the closet. I modified the metal outer housing of the unit to properly enable air flow over the condenser coils. It had a vent to blow into the trailer that I was able to simply aim upward. It was extremely effective, very inexpensive and as it rested directly on the floor of the trailer, did not create any stresses on the shell. Somewhere in this website I had posted all the details, including photos.
I dislike roof units due to their added stresses on the shell, which I believe to be especially destructive while the unit is in tow and bouncing along the road. If I did have a roof unit one, I would create a travel brace going from the floor to the ceiling to completely absorb any stresses while the trailer was being towed.
Steven Tonnesen is offline   Reply With Quote
Old 04-19-2020, 11:57 AM   #11
I had a roof mount A/C on my 98 13' Scamp. Camping World removed it and installed 3 speed fan which I really like. Don't know if my unit's roof was reenforced at factory because I bought it used. I use a 75 watt 1 gallon misting fan for cooling. I set in on the table. I can also run it off a 250 watt inverter (for about an hour). The misting fan sits in that couch corner when not in use. I bungee cord tie it down when on the road.
Dan Chapman is offline   Reply With Quote
Old 04-19-2020, 12:13 PM   #12
Morro Bay
looking for a/c to use in 1977 13' scamp which can't take the roof a/c. I'm thinking about using a portable unit and making a conduit to run into the scamp via a window, and keep the actual unit outside (space consideration). Alternatively I'm thinking of using one of those and placing it in the closet... and add a vent thru the wall. I can't seem to find a reasonably priced mini split.... Has anyone done this with a portable unit? Any recommendations on equipment? Thanks!
KathyR is offline   Reply With Quote
Old 04-19-2020, 05:06 PM   #13
When I had a Scamp 16, the previous owner had mounted a small window unit in the lower part of the closet. I modified it by cutting a large hole in the top of the a/c's metal cabinet. The attached drawing and pics should be enough to indicate how it was designed. Outside air was drawn in the top vent shown and hot air through the condenser went out through the large vent shown.
Old 06-07-2020, 08:05 PM   #14
Borden's Avatar
Name: Borden and Carole
Trailer air
-ClimateRight CR-10000-ACH 5000 btu and 2500 btu Small House, Garage, Shed Air Conditioner;
-Euromac AC2400 Split Air Conditioning System White
-Zero Breeze Mark 1 Air Conditioner
12 lbs and 1100 btu "not evaporator real compressor unit"
All should do a small trailer and the last one is so light weight; supply stable 12V, 15A DC power used to run, 120-150 Watt or you can get it with its own battery.
Our postage stamp in heaven.
Old 06-07-2020, 09:59 PM   #15
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
The back window of a 2013 Scamp Std opens wide enough to allow mounting a 5000 BTU Frigidaire window unit. That's what I've used on both our Scamp13 and Scamp16 trailers. You can't travel with it in the window but it cools the trailer adequately and, at Best Buy, only cost about $115 (in 2013 dollars).
I pad the window track with pipe insulation or pool noodles and put a wooden platform through the window that the AC sits on. The back edge of the wooden platform is braced down to the rear bumper to help support the weight.
In addition to the wooden platform under the AC, I currently use a couple of thin painted plywood frame pieces that pull up snug to the pool noodles surrounding the window opening on the inside and the outside of the trailer to prevent hard rains from leaking into the trailer.
The AC power can be run down to a campground power pedestal or powered by a little Honda 2200i quiet generator when dry camping.
The 5000 BTU window unit is much quieter than the top-mounted AC unit!
For 1 night enroute stops, flipping the switch on a top-mounted unit is less effort than setting up the mount and AC unit in the back window. But, the window unit is MUCH cheaper and much quieter. For multi-night outings, it is very nice and certainly worth the few minutes of effort.
If you look at older posts in the forum, you can probably find a number of AC mounting designs. If not, maybe I can send pix of ours in a few days.
Living in the Midwest, we often go farther north in the summer and farther south in the fall and winter months. During most of those trips, we don't need the A.C..
However, there always seem to few a few trips into high heat and/or humidity. For those trips, the window AC is very welcome!
Best of luck to you!
Ray
rdickens is offline   Reply With Quote
Old 07-18-2020, 06:14 PM   #16
Trailer: Casita 13 ft
I installed a 5000 btu window AC in the rear window of my 13' Casita Patriot. It worked great and my Hondo 2000i could run it just fine. The only issue that I had to overcome is the rear window is not exactly verticle so getting the AC to slope down in back took some thought. I used 2x1 oak to construct an inner and outer frame that would clamp the AC in place using bolts and thumbnuts. That way I could take the AC out easily. Since the AC was smaller than the opening in the window, I made a filler that would slide over the AC from the outside, then used aluminum tape to seal any air leaks. A little paint to match the tape to the trailer and it was done.
I used it that way for years and traveled a lot of rough forest roads without the least problem. The AC never moved unless I took it down for cleaning and service. It would keep the trailer cool in 100 degree plus heat. Some folks think it looks a little hillbilly from the outside but I just smile and enjoy my cool trailer.
jim_ivy is offline   Reply With Quote
Dog Dilemma Gleam B General Chat 78 08-08-2013 12:50 PM
Fiberglass Dilemma Tuanis General Chat 15 07-19-2013 11:21 AM
The "screen door" dilemma... PaulOWindsor General Chat 6 07-19-2011 11:43 AM
Electrical Dilemma (Crossing fingers and not wires!) Legacy Posts Problem Solving | Owners Helping Owners 13 06-06-2003 09:03 PM
