Advice and Ideas Needed for Boler Repair - Page 2 - Fiberglass RV
Old 03-10-2016, 06:29 PM   #21
Connecticut
I don't plan on replacing the fiberglass furniture just the kitchen cabinets and I may only cut the front out of the bottom cabinets and replace it with wood because it has been so badly mutalated and I was not aware tholse little bars supported the roof thanks.
Kevin98 is offline   Reply With Quote
Old 03-10-2016, 07:53 PM   #22
Connecticut
I am also trying to figure out a 12v system how should I hook up batteries etc. and how should I charge them should I use an inverter?
Old 03-10-2016, 08:46 PM   #23
Trailer: 1975 Boler
Quebec
Kevin,
I'm working on a Boler as well. I feel your pain...
How do you manage to post pictures without them being upside down? That's amazing to me...! I'm using an ipad as well.
Uncle Cereal is offline   Reply With Quote
Old 03-10-2016, 09:19 PM   #24
Connecticut
Hahaha it took me an hour to figure out how to even put up a picture
Old 03-10-2016, 09:34 PM   #25
CliveAlive's Avatar
Trailer: Boler American (#3104)
Originally Posted by Kevin98 View Post
Here is the outside
That looks like a Boler American you have there.
The serial number should be on a plate on the left side of the tongue. What number is it?
There's a registry/history somewhere on here. I'll see if I can find it.
This is the thread I was thinking of ...
http://www.fiberglassrv.com/forums/f...ere-42676.html
Old 03-11-2016, 08:31 AM   #26
Trailer: Escape 2017, 17B
You can find out a lot about 12v systems on the solar thread on the forum. If you run 12v appliances you won't need an inverter. The inverter changes DC to AC. I have a fridge that runs on 110/12 but will be taking it out and using a 12v fridge instead. I plan to sell it if you are interested, but that's a couple of months in the future.
Christian in FL is offline   Reply With Quote
Old 03-11-2016, 11:36 AM   #27
Connecticut
My only concern is that 110 volt appliances are much easier to come by and a lot cheaper.
Old 03-12-2016, 09:46 AM   #28
True that 110 v are cheaper, until you factor in the campground fees where you will need to stay to have electric hookup. Those can be up to 50 - 65$ nightly. In some rv parks they go up even higher, esp at peak season times.
Old 03-12-2016, 08:41 PM   #29
Connecticut
Yes that's true I've decided to not put any large appliances in it I have a gas stove and an ice box and no furnace I just have and old Colman catalatic heater I'm keeping it very simple as most places I go camping there is no power or anything.
Old 03-12-2016, 09:10 PM   #30
Davie B's Avatar
Trailer: Lite House
I thought that I had a big project.
Davie B is offline   Reply With Quote
Old 03-13-2016, 06:26 PM   #31
Connecticut
Here is the new floor sections in
Old 03-20-2016, 09:52 PM   #32
Hi there! I've also got a 13 foot '68 Boler. Was not in quite as rough shape (was my gramp's) but I only did the minimum in terms of repair to make it liveable inside and I no longer have the stove in, no fridge (only ice box, etc.). You're for sure doing a much more thorough job than me!
Question for anyone on this thread: I've got serious door sag issues. Have watched some youtubes about it, but none that address the issue with my ancient hinges. Should j just take the door off and try to re-hang with new hinges? And any recommendations on doing this or resources to point me to? I've also attached a photo of the pretty massive gap in the side of my door. I don't think re-hanging the door is even going to fully address the gap, but it's a start, I guess.
Thoughts?
ImageUploadedByFiberglass RV1458532171.348190.jpg   ImageUploadedByFiberglass RV1458532265.938106.jpg
sooveroo is offline   Reply With Quote
Old 03-20-2016, 10:14 PM   #33
Suvi, I think you're going to need to talk to Ian Giles about the hinges. I know you've got one of the few original flat top Boler's and those were the hinges used before they change to the two-bolt, brass ball and spring. And, you can't get those hinges as new anymore either. You'll probably need to change to the three-bolt, Scamp hinge.
Old 03-20-2016, 10:29 PM   #34
Yea, Donna. I definitely will. Actually bought the ball and spring set from him without having looked at the hinges closely all winter and then realized they wouldn't work unless I entirely replace hinges. He's in Calgary I think. Tempted to take my trailer out there in the fall and let him have his way with it 😂
boler
Boler fiberglass repair advice.. spaghettiroad Hi, I am.... 28 11-15-2015 06:12 PM
Need some ideas on rot repair under water tank cmartin748 Problem Solving | Owners Helping Owners 4 11-03-2015 05:55 PM
Help needed - Boler window repair Johnny M Modifications, Alterations and Updates 2 05-31-2015 08:05 PM
Ensolite Painting and Seam Repair Advice morbank Problem Solving | Owners Helping Owners 6 04-26-2012 10:35 AM
Boler Repair Ideas/Other units also Legacy Posts Problem Solving | Owners Helping Owners 0 08-19-2003 08:15 PM
