Air conditioner input air draw - Fiberglass RV
Old 10-02-2020, 11:09 AM   #1
Trailer: scamp 13
Does the dometic air conditioner in a 2015 Scamp tend to draw air from inside the Scamp or from outside? I am kind of thinking inside based on the filter location, but I am not really sure and couldn't find anything n the manual. Thanks very much.
zack sc is offline   Reply With Quote
Old 10-02-2020, 11:48 AM   #2
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
All rooftop mounted AC's have two separate air paths. There is one for the interior of the trailer where air is pulled through a filter, run across cooling fins mounted to tubes and expelled via the vents. That cools the interior air. The second path is outside the trailer where outside air is pulled over fins mounted to tubes and is heated then blown outside the trailer. This process removes heat (cools down) a refrigerant that then runs into the tubes with the cooling fins, thus cooling the interior air. Unless the unit was installed incorrectly or there is some failure inside the unit, these two paths for air should never mix.
Old 10-02-2020, 11:56 AM   #3
Trailer: scamp 13
Thanks very much Alex. So then running the air conditioner would not bring in dirty air from the outside, if you’re in California, as I am, and running an air purifier inside the Scamp. ? That is really helpful and reassuring. Thank you.
Old 10-02-2020, 11:57 AM   #4
Trailer: scamp 13
So then, that seems really different from a car, where you have a choice of drawing air from the outside or recirculating inside air through your air conditioner. Am I understanding that correctly?
Old 10-02-2020, 11:59 AM   #5
Trailer: scamp 13
Does a window mounted air conditioner in a house tend to draw air from the outside, or does it just cool air that’s already inside the house?
Old 10-02-2020, 12:01 PM   #6
Alex Adams's Avatar
New Hampshire
A window air conditioner works the same way as long as it is installed correctly.
Old 10-02-2020, 12:46 PM   #7
you have to recirculate the air inside the box to cool it otherwise once the box is full no more air will blow in except for leakage loss.
Old 10-02-2020, 12:52 PM   #8
Orlen Wolf's Avatar
Originally Posted by zack sc View Post
Does a window mounted air conditioner in a house tend to draw air from the outside, or does it just cool air thatís already inside the house?
Some home window air conditioners have the capability of either recirculating inside air, usually marked recirc on the control, or drawing outside air (called makeup air) through the chiller coil. Others have a separate control to switch between them. The ones I've seen do not filter the makeup air so you bring in whatever is in that outside air (smoke, small bugs etc.). If you draw in outside air there needs to be an exit for the overpressure so one other window in the house has to be opened a little.
Orlen Wolf is offline   Reply With Quote
Old 10-02-2020, 06:31 PM   #9
Trailer: scamp 13
Thank you very much Orlen and Alex. I never understood this and this is really helpful and interesting.
Inverters and Power Draw honda03842 Care and Feeding of Molded Fiberglass Trailers 27 11-16-2011 12:16 AM
amp draw Dan B Problem Solving | Owners Helping Owners 18 05-30-2008 07:50 AM
Any Draw On my Battery? Gerry Problem Solving | Owners Helping Owners 8 08-17-2007 04:03 PM
Low amp draw DC fluorescant light Joe Z Modifications, Alterations and Updates 6 07-08-2007 04:33 PM
fridge draw colin k Problem Solving | Owners Helping Owners 24 03-30-2006 10:03 PM
