Hi!
I’ve already learned so much about
scamp restores through the years of threads here, so thank you!
My wife and I picked up a 2001 16
scamp here in Oregon. It had clearly been outside in the weather for years uncovered. Pretty rough shape, all the rivets were pretty much leaking,
windows full of debris,
fridge vent cracked and leaking. All that to say I started pulling everything out to get a better scope on possible water damage. So far I’ve discovered significant rot along drivers side rear, about 2ft worth with some spots bad enough to shove a screw driver through to the underside. Found some rot under the water heater. And under the
fridge.
At this point I started pulling the water lines, gas and
electrical to get a better view and see if it’s possible to repair the rot by impregnating it with epoxy, I don’t think I’m going that route anymore since the top was painted white and is not allowing moisture to dry out of the rotted sections. They are all reading over 35% moisture content with fans and dehumidifiers running for several days.
So here is where I’m at, I’d like to just replace the subfloor with plywood that’s glassed on bottom, edges and at least the top several inches from the outside edge. I would cut the top tab and try to leave the bottom tab attached.
My question to you all is, what
fiberglass mat/cloth are you using for tabbing? I was thinking a 4” wide 1708 Biaxial
Fiberglass Mat for the top tabbing. And using west system’s 105/206 epoxy. And adding 406 to make a thick epoxy for bottom tab to lay the plywood in. My profession is custom woodworking so I’m pretty familiar with epoxy and feel relatively confident in glassing but would love advice!
Are you guys doing one glass layer only, or multiple? My shell is sitting on the frame front and back, would it be foolish to do one section at a time (back dinette first, left or right right sides after) I imagine it would make it likely impossible to pull the shell a 1/8”-1/4” off the frame doing it this way?
Thanks in advance
David
