I have put a set in my kitchen, under the upper cabinets. The
Fiber Stream has a stick built interior. The wood paneling doesn't have any reflective properties, like white
fiberglass does, so I got a roll of shiny mirror-like tape and put a strip on the bottom of the upper cabinets. I drilled 2 small holes spaced 3/4" apart thru this tape area, near where each end of a tube would be, and ran a "zip-tie" in one and out the other and around the tube. 2 "zip-ties" hold up each tube. Between the tubes, I drilled one hole to run the wires thru, and mounted the blue power pack and the switch inside the cabinet.
