Are The Casita 17 Deluxe And The 17 Standard The Same Shape? - Fiberglass RV
Old 09-26-2020, 10:08 AM   #1
Hi I have a casita 17 deluxe shell that I'm renovating and I was wondering if I could cut out a hole for a front window like in the standard. Are the two shells the same shape? Would a standard front window fit properly if I cut out the correct size hole in my deluxe?Click image for larger version
Wade R is offline   Reply With Quote
Old 09-27-2020, 06:54 AM   #2
Jon in AZ's Avatar
Yes, same shape. But I’m pretty sure the “standard window” is just a piece of plexiglass installed with a locking gasket. The exact size is not critical as long as you don’t make it too big, and the materials to make it are available from a number of sources.
The fiberglass cutout is commonly used to make a rock guard with edge trim and some attachment hardware. Forum member Ian Giles sells high quality stainless steel hardware online at www.campingtreasures.com.
Old 09-27-2020, 07:03 AM   #3
How large of a window are you looking to install, and what is your goal for interior furnishing at the front end of the trailer?
You might also find some difficulties in attempting to install a larger window due to the very pronounced compound curvature of the front end.
As far as your question about the size and shape of the trailer shell, yes the Deluxe and Standard are exactly the same. The differences lie mainly in that the Deluxe has the front bathroom, while the Standard didn't have the bathroom. There are also some differences in the way of installed equipment and appliances, but the bathroom is the single biggest difference.
I have a 2008 17" SD, which didn't have a window because it had the bathroom. I never liked not being able to see out towards the front of the trailer without having to actually go outside to do it, so I quickly remedied that situation with my non-opening "port hole" style window that I mounted in the bathroom, dead center in the front end. Now I can keep an eye on my tow vehicle and any other front-end activity without having to go outside.
I also added a 3-way switch to the little propane tank convenience light up front and I installed another 3-way switch inside, so now I can also have the front area lit up to see outside at night just by turning on my inside switch.
Old 10-03-2020, 11:26 AM   #4
Probably gonna attempt to add window approximately the size of the one that comes in the bathroom-less casitas. I'm going to build out a totally custom interior. I'm planning on extending the bed / dinette 6" to make it a queen (green), replacing the current kitchen area with one large closet w/ drawers (blue), and turning the bathroom / seating area into one large L shape kitchen / storage area (red).
Old 10-03-2020, 12:00 PM   #5
Sounds like you've got quite a project going on. Be sure to update and add pictures as you go along so we can see the transformation. Should be an interesting layout when it's done. Good luck with your upgrades.
Old 10-03-2020, 12:40 PM   #6
Tennessee
Yes. The fiberglass molds are the same.
Rockytop is offline   Reply With Quote
Old 10-07-2020, 08:42 PM   #7
Porthole in head?
Where did you get the porthole window Greg, and how tricky was it to install?
Procyonid is offline   Reply With Quote
Old 10-08-2020, 08:37 AM   #8
The company I ordered my front window from is:
Motion Windows
6005 N.E. 121st Ave.
Vancouver, WA 98682
Their phone numbers are:
(Toll-free) 1-800-468-4323
(Local) 1-360-892-2029
(Fax) 1-800-213-1274.
My particular "front" security viewport window is: 10" wide X 6" high, Series 1600 single pane, rectangle, stationary, black anodized frame, solar grey tint, 2 1/2" radiused corners, 1 5/8" wall thickness. They are a good company to work with, they understand RV and trailer windows, and they'll fabricate a window for you to your specifications.
Here is a link to their website: http://www.motionwindows.com/custom-...n-vehicles.php
The hardest part is doing a lot of measuring and stepping back to "eyeball" it several times to get it centered properly. You will actually be going through two separate bulkheads to install the front window if you do this mod. The outer trailer hull is one of them, and the separate fiberglass bathroom enclosure is the other one you'll have to cut through. Then there is a space between the two of about an inch or so, along with the ubiquitous wall carpeting, which they install before they put in anything, and then the bathroom module goes into the trailer, before they mate the upper and lower trailer sections at the belly band.
casita
Propane and Battery at same time chud13 Problem Solving | Owners Helping Owners 8 05-02-2014 11:01 AM
Door thickness and shape. Cat futrell Modifications, Alterations and Updates 3 08-19-2013 06:39 PM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
