Attaching plywood to the fibreglass floor - Fiberglass RV
Old 06-01-2020, 11:14 PM   #1
Trailer: 1975 Ventura
Yukon
Hi everybody, The original cabinet which housed the sink/stovetop/fridge was removed by a previous owner. The spot where it used to sit has no plywood on the floor. Its just the exposed fibreglass. I want to re-build a cabinet in that same spot. Should I use adhesive to attach plywood to the floor before i start construction? Any tips? Thank you, Sonny.
sonny75 is offline   Reply With Quote
Old 06-02-2020, 08:20 AM   #2
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
I always use polyester resin and glas to mount anything to the shell.
I've never had a problem with this method and is how the manufactures
do it, or at least did it on my boler and their stuff is still holding 46 years later.
Post 149 in this thread
https://www.fiberglassrv.com/forums/...r-55601-6.html
is an example of attachment.
Fred
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
FRED SMAILES is offline   Reply With Quote
Old 06-02-2020, 10:45 AM   #3
Yukon
Thanks Fred.
Old 06-02-2020, 11:30 AM   #4
Yukon
Was 'glas' a typo?
Old 06-02-2020, 12:16 PM   #5
Trailer: Ventura 73í
Iíve read up on this too. Some of our plywood had water damage. Thereís a lot online re bonding wood to fibreglass...
murffie is offline   Reply With Quote
Old 06-02-2020, 10:52 PM   #6
Kootenay's of BC
Originally Posted by sonny75 View Post
Was 'glas' a typo?
Ya the fiberglass mat used in the process.
Check the pics in the link
Fred
Old 06-03-2020, 12:26 AM   #7
Raspy's Avatar
Trailer: Black Series HQ19
Smith Valley, Nevada
Fred is obviously very talented with Polyester and fiberglass.
But if you want a simple way of gluing plywood, or hardwood blocks to fiberglass, you can simply use a one part polyurethane like 3M 5200. This bond will be stronger than the wood or the fiberglass and is as easy as squeezing it out of the tube. The wood can still be soaked up with resin or glassed over later if desired. Another good choice is Marine Tex epoxy. It is a two part white putty that also bonds stronger than the wood or the fiberglass.
Here's a link the the 5200:
https://www.3m.com/3M/en_US/company-...3241623&rt=rud
I used a lot of this on my fiberglass boat to mount bulkheads, cabinets, or wood blocks to screw into. It retains a bit of flexibility, so you can glue the edge of a bulkhead to the hull and not have too much of a hard spot that adds extra stress.
Raspy is online now   Reply With Quote
Old 06-04-2020, 12:55 PM   #8
Yukon
Thanks for the advice
Old 06-10-2020, 06:52 PM   #9
Trailer: Planning stage
When I do custom boat restorations I have been using PC-11 epoxy adhesive Paste .i like it better than Marine Tex ( except if it has to cure real fast ) it has a 20-30 minute work time but does take overnight to cure. Then it is easy to sand ,form and paint as well as being 1/4 price of Marine Tex. You can also use it if thereís water present and itís waterproof so works well on bottom of doors. Just my 2 cents worth.
Sammy Joe Quattry
4 Generations of Fishermen, 1 ROBALO
https://robaloboatowners.net/forums/
Sammy Joe is offline   Reply With Quote
Curtain Rods - Attaching To Fibreglass? Eggbert Modifications, Alterations and Updates 6 07-26-2015 06:34 PM
Plywood floor - what do I look for? Melanie Problem Solving | Owners Helping Owners 6 07-03-2011 08:38 AM
Plywood floor replacement supplies Mike Shackelford Problem Solving | Owners Helping Owners 3 10-08-2009 07:17 PM
Floor replacement Options - OSB vs Plywood. Oliver P Problem Solving | Owners Helping Owners 11 08-11-2009 08:34 PM
Plywood Floor Replacement 72 Boler Annie T Problem Solving | Owners Helping Owners 5 07-24-2007 10:19 PM
