Atwood furan e - Fiberglass RV
Old 09-22-2020, 04:25 AM   #1
Trailer: Park liner
Oriental
Atwood furan e
I have a park liner with an atwood furnace no thermostat in the camper how do I turn it on and regulate it
Frtonys is offline   Reply With Quote
Old 09-22-2020, 06:05 AM   #2
Install a thermostat (page 7)?
Old 09-22-2020, 07:33 AM   #3
Raz
Raz's Avatar
The thermostat connects to the furnace with two wires. Connect the ends together, which is what the thermostat would do, and the furnace should come on. Shortly after that it should ignite. If it fails to ignite it will turn off. Then you have a problem. On mine I found a cold solder joint on the control board. The common issue is a bad sail switch.
Once repaired, my Atwood works quite well. The Atwood thermostat is not of very good quality but since I use it manually, as a on off switch, I haven't bother replacing it.
Good luck.
Old 09-22-2020, 01:44 PM   #4
Attwod furnace has an on off switch under the face grill. There should be a thermostat. Attwoods thermostat is pure junk get a home wall digital unit for milivolt connection. Look up the installation and operation manual for your furnace on line.
Problem with Atwood furnace JPraeder Problem Solving | Owners Helping Owners 8 06-06-2013 06:30 PM
Atwood stabilizers-you pay to ship Tony Nowak Classified Archives 0 09-11-2008 11:06 AM
Atwood Everest Star 7912 Furance = pros and cons Kurt in BC Modifications, Alterations and Updates 10 02-18-2008 12:05 AM
Installation of an Atwood Hydroflame 8500-IV Timmy G Problem Solving | Owners Helping Owners 0 10-06-2007 12:16 PM
Explain Atwood Heater jefh Problem Solving | Owners Helping Owners 6 12-15-2005 01:35 PM
