AuTOWbrake controller installation help - Fiberglass RV
Old 04-30-2018, 06:56 AM   #1
Aaron Cohen's Avatar
Trailer: Casita Spirit Deluxe 16 ft ('Lillypod')
Hi, I'm picking up a new to me '96 Scamp 16 layout 6, and wonder if anyone has wired an Autowbrake controller in a Scamp. Wondering where the best place is to splice it into the Scamp's wiring. I'm a wiring novice, and know nothing about electrical systems, other than connecting blue to blue, etc. Does the Scamp have a junction box in addition to the converter panel?? Thanks.
Aaron Cohen is offline   Reply With Quote
Old 04-30-2018, 07:37 AM   #2
No junction box.. the umbilical goes into the trailer and is connected to the wiring inside, in my case using wire nuts. If I were putting in a AuTWObrake I would also install a junction box. Might put it outside, but maybe inside is better if there is room. I understand that the AuTOWbrake can be installed inside also (if there is room). The junction box should make for better connections and make it easier to replace the umbilical cord when it becomes necessary (and it will sooner or later).
Here is a generic Scamp wiring diagram but I caution you to verify things since a trailer of that age could have all sorts of changes made. You might need on site help with that.
I'm not sold on the AuTOWbrake yet. I have a few concerns, one of which is based on my assumption that it uses the trailer battery to power the brakes. If that is right, and you don't have a charge line or for some other reason the battery gets depleted, then the brakes might fail. I'm sticking with my Tekonsha P3 Electronic Brake Control.
Old 05-07-2018, 10:33 AM   #3
Update: According to Evelands (Scamp), the AuTOWbrake controller does not in fact use the trailer battery. It still requires the power wiring (7-pin) from the tug for the brakes. So it does save you from having to run wiring into the passenger compartment, and maybe tapping onto the brake switch. It still seems to me that is still limited on power level adjustments.
If I had a tug pre-wired for a brake controller with a wring harness in the dash, I would never use the AuTOWbrake. But if I did not have that pre-wiring, I would consider it.
help with WFCO installation Garycamper Problem Solving | Owners Helping Owners 4 01-24-2021 09:03 AM
Solar Charge Controller Installation kevin61 Modifications, Alterations and Updates 3 02-22-2009 09:20 AM
Need Help With Installation of Fantastic Fan in Scamp Carol H Problem Solving | Owners Helping Owners 7 08-26-2008 10:13 AM
Prodigy Brake Controller Installation V'sGlassSleeper General Chat 8 07-11-2007 02:21 PM
Brake Controller Installation murrayg Problem Solving | Owners Helping Owners 9 04-03-2007 01:11 PM
