Axle Help on a Trillium - Page 2 - Fiberglass RV
Old 09-25-2017, 07:56 PM   #21
When I did mine, I lifted the shell off. Pulled the frame out and loaded it into the pickup.
I went to the Axle place and they measured it for me. Of course, they immediately noticed that the arm was installed as a "leading" angle as opposed to the normal "following" angle. So, I had mine made in the correct configuration and with a 22.5 degree down angle.
Trill136 is offline   Reply With Quote
Old 12-01-2017, 04:53 PM   #22
manitoba
Had a new dexter axle put on mine this summer. The shop sandblasted it, did the recall fix, put a new jack and 2" receiver on it and panted it. They did not change the arm orientation. Does it matter?
Reade is offline   Reply With Quote
Old 12-01-2017, 05:20 PM   #23
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Reade, the trailing arm starting angle that you specify needs to allow enough space between top of tire and top of wheel well. Four inches or width of your fist is considered adequate space.
Old 12-04-2017, 07:50 AM   #24
Trillium
Haven`t replied in a while. I am waiting for my axle to be installed on our Jubilee. Once it`s complete I`ll send details.
bigEZbob is offline   Reply With Quote
axle, trillium
Need help Trillium 4500 axle Randy Bishop Problem Solving | Owners Helping Owners 4 09-04-2016 08:11 PM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
