B1700 belly band fix help and more - Fiberglass RV
Old 03-27-2021, 06:25 AM   #1
Trailer: Boler 17'
Good morning. I recently picked up a 17' boler, insure of the year (77-79 I assume). Overall it seems to be in fairly decent shape but a piece of the banding holding 2 halves together us broken and missing. Any ideas if and what I can replace this with? Also my door seems to be cracked in the middle, it has some flex to it, too many years of slamming it maybe??. Can that be fixed? I'm sure I'll have many other questions along the way. I've renovated an airstream so a lot of parts, gaskets etc i can figure out where to source from. Haven't figured out how to post pictures yet.
scamp53 is offline   Reply With Quote
Old 03-27-2021, 10:43 AM   #2
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I believe your trailer is a '77. The belly band is a C channel available at any metal supplier. The problem would be bending it without it kinking.
Other area's to look out for are at each end. Mine had the front table hardware screwed right through to the back of the bellyband causing it to leak. Same with screws in the rear. I fibreglassed wood blocking to the walls in this area and attached everything to them.
Old 03-27-2021, 04:58 PM   #3
Trailer: Boler 17'
Thank you. Thankfully, she only requires a small section to the left of the door. 2-3' maybe. It seems fairly flat there. My table is not screwed to the wall, I am not sure if it was a previous mod but it is a free standing pedestal. We had a bit of snow here last night and it looked as if only one window and by the door had water spots. I think I lucked out on this one. Can't check wayer yet as dump valve is broken but fridge, stove and furnace all work.
Butyl tape to fix belly band seal. sonny75 Problem Solving | Owners Helping Owners 6 07-10-2020 08:42 AM
Belly band help needed Island Claire Problem Solving | Owners Helping Owners 6 03-24-2015 07:43 AM
'76 Trillium Belly Band Leak Fix georgewa Modifications, Alterations and Updates 6 04-12-2014 09:29 AM
Help: Trillium Belly Band msinger919 Problem Solving | Owners Helping Owners 11 11-13-2012 09:35 PM
Trillium Fix Update - Belly Band Caulk Ruth C. Problem Solving | Owners Helping Owners 1 06-16-2011 10:37 AM
