Back-up camera: dual video inputs - Fiberglass RV
Old 06-08-2017, 11:09 AM   #1
armugwump's Avatar
Trailer: 07' Casita Freedom Delux
Arkansas
Has anyone successfully installed a dual input (dual camera) backup viewing system on the tow vehicle and on the RV. I would anticipate a wired system would have less problems. A line switch would be necessary at the "monitor screen". This would allow backing the RV into a campsite (when the input line #2 would be connected and then disconnected during the RV setup .....thus allowing later easy backup/connection to the RV in anticipation of leaving the site. The "RV video line" would be approximately 35 feet long with the "permanently connected "vehicle line" would probably be about 15 feet". The camera power source for the would be permanent connections to the backup light circuit.
If you are satisfied with the setup, what supplier/manufacturer do you have for the cameras and the monitor and what type/source of extra "RV video" line will be necessary. If you were to install another similar system what change/changes would you make in the "setup/ equipment"?
Any thought appreciated on this
armugwump is offline   Reply With Quote
Old 06-12-2017, 02:35 PM   #2
stefman's Avatar
Trailer: 76 Trillium 1300
Waterloo, Ontario
I just bought one of these for the tow vehicle.
Wireless Car Rear View Kit 7" LCD Mirror Monitor + Reverse Back up Camera USA F | eBay
It works pretty good and there are 2 inputs. I did use both inputs on the other tow vehicle I had. There is a button you press on the monitor to switch between the two cameras. I absolutey recommend throwing the wireless portion in the garbage. I just ran an rca cable from the back of the trailer to the front and same in the tow vehicle (2 for you) and hook the wire up when hooking up the trailer.
The wife absolutely loves the fast that when looking in the rear view mirror when towing it looks like you are looking out the back of the trailer. Absolutely no guessing if you have cleared a vehicle you are passing and you always know when you are being tailgated.
When used as just a mirror it is not great but does the job. I usually just remove it and put it in the trailer when not towing but to each their own.
Also, I would hook the power for this unit to a switch. Mine just turns on with the parking lights as in I would never tow without being as visible as possible. I leave it on the whole time I'm towing down the road. Towed from home to the farthest point east in Canada and would never do it again without this set up. For you, just use a switch or whatever as you may not want to leave it on when not towing and just using it as a backup camera on the tow vehicle. I did run the rca cables as you suggest.
stefman is offline   Reply With Quote
Video Back-up camera. Which one? David & Terry Problem Solving | Owners Helping Owners 6 02-28-2017 06:46 PM
VR3 wireless back up camera John Perry General Chat 2 02-11-2017 10:20 PM
$29.99 back up camera Perry J General Chat 14 02-05-2013 01:29 PM
Back-up Camera on a FGRV Sandra L Care and Feeding of Molded Fiberglass Trailers 27 11-24-2009 09:38 PM
Back-up Camera on a FGRV Sandra L Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
