Backup lights and camera - Fiberglass RV
Old 09-27-2020, 07:57 AM   #1
Borden's Avatar
Name: Borden and Carole
Hi need help; have the original Earlton manual for our trailer. Want to wire in two backup lights and a camera to the 7 pin wiring setup.
White is ground 14G " - "
Red is Stop and L.H. turn signal 16G
Black is interior lights and refrigerator plus battery charge 12G " + "
Blue is Brake control 12G
Green is Tail and running lights and plate light 16G
Brown is Stop and R.H. turn signal 16G
Yellow is Auxiliary runs too the tail lights area and is listed as extra auxiliary circuit or auxiliary ground. 16G
What do I connect the backup and camera too? Would it go to the auxiliary and if so do I have to change any wires in the car?
did a repost in Electrical with added details
Thankyou in advance
Borden
Our postage stamp in heaven.
Old 09-27-2020, 09:49 AM   #2
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
I installed simpler for me.
I installed a Garmin wireless camera that activates on my GPS when I turn on my parking lights I can switch from map to rear view if needed ...
I could have connected it to my reversing lights, maybe later, but occasionally I like to be able to watch what's going on in the back, which I couldn't do if the camera is installed on the reverse only.
Note that it is a matter of choice that is yours
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 09-27-2020, 10:12 AM   #3
Borden's Avatar
Which wire to use for backup in 7 pin
Thanks wanted it to only come on when in reverse; think yellow wire is the correct wire to use for power to the backup lights; based on configuration above.
Would check car for backup to that wire.
The camera is wireless to screen in the car. Could use the parking lights for camera as it is a better idea from what you have explained and then use yellow wire for backup lights. Do you know if yellow wire for backup will handle the led backup light loads?
Thanks
Borden
Old 09-27-2020, 03:30 PM   #4
Gilles's Avatar
Quebec
Thanks
Borden
The center connector is for backup light, or backup camera if it's necessary.
You will find the diagram on this site :
https://www.google.com/imgres?imgurl...MygBegUIARCVAQ
Gilles
Bigfoot 25B21RB.
Old 09-27-2020, 06:22 PM   #5
Trailer: 2016 -13' Scamp
Massachusetts
Following thread.
herons is offline   Reply With Quote
Old 09-28-2020, 04:22 AM   #6
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Thanks
Borden
As has been stated, the center conductor on the 7-pin connector is used for back-up lights on trailers. Common sense would indicate that yes, it will handle the LED load. Most backup cameras designed for trailer use have infrared lights for night visibility, as does the camera on almost all modern (tow) vehicles. It seems to me that wiring in a camera which both illuminated what is behind and displays a more encompassing “image” of obstacles would be preferable to illuminating the limited viewing area provided by mirrors. And both lights and a camera could be utilized; the power required would be supported by the tow vehicle’s wiring.
light, lights
Wireless Backup Camera Interference Problems Fran L Problem Solving | Owners Helping Owners 6 08-22-2013 02:32 PM
Backup Camera--Koolertron Kevin K General Chat 3 10-17-2012 11:53 AM
For Sale: Backup LCD / Camera - ONE DAY ONLY fusedlight Classified Archives 5 04-09-2012 08:59 AM
Installing a Backup Camera on the TV License Plate Kevin A Problem Solving | Owners Helping Owners 8 12-28-2009 08:07 PM
» Trailer Showcase
Swanky
Donna R
2013
Daniel A.
