Bar fridge ideas for Trillium 4500 - Fiberglass RV
Old 08-19-2018, 06:30 PM   #1
Chris, J's Avatar
Trailer: Trillium 4500
Hi everyone
I would like to increase the size of the fridge in my 4500 Trillium. I'm thinking about installing a bar fridge. In the future I would like to run it off solar. Does anyone have any suggestions on the largest fridge possible if I cut away the space?
Thanks in advance
Chris
Chris, J is offline   Reply With Quote
Old 08-19-2018, 06:39 PM   #2
Trailer: 2009 Escape 17B
You'll need a trailer-full of batteries and solar panels to run a bar fridge.
Old 08-19-2018, 08:24 PM   #3
Steve Hammel's Avatar
Trailer: Casita 17
Nevada
They do make 12v compressor fridges but they're not cheap. When I had my 4500 I converted it to one that I found on ebay. It worked fantastic and I actually got 2 or 3 days use on a single charge without recharging. If driving in between to charge the batteries it never discharged. They are usually used on boats and in some nicer big rigs.
Old 08-20-2018, 07:44 PM   #4
Trailer: Triple E
My experience is that 12 volt fridge systems are not very effective. If you want to boon dock you are better off to buy a fridge that runs off of 120 volt AC as well as propane. Many of the newer r v fridges also require 12 volts to operate the control systems.
If you are planning to stay only in campgrounds that have services just buy a decent 120 volt bar fridge.
Gerry Kiernan is offline   Reply With Quote
Old 08-20-2018, 08:00 PM   #5
Trailer: Casita 17
Nevada
Danfoss "compressor" 12v fridges are probably the best made. They FAR outperform propane. You must be talking about those cheap heat sink ice box pieces of junk. The 12v "compressor" fridge doesn't need all night to cool down and they don't have to be leveled when you get to your spot. In fact all the new Trilliums come with them as standard equipment.
Old 08-20-2018, 08:10 PM   #6
Trailer: Triple E
In all honesty I have not heard of these fridges before. It would be great if they perform as well as you indicate.
Old 08-20-2018, 08:17 PM   #7
Trailer: Casita 17
Nevada
Yes they are great. They've used them on boats for a long time. Propane fridges used on 12v suck and 110 fridges used with 12v convertors suck. The Danfoss compressor fridge is just like a home fridge only they run "efficiently" on 12v. They are pricey though. Prices are getting better as a whole new market has started with the advent of solar. I have personally had 3 of them now and much prefer them to propane.
Old 08-20-2018, 08:54 PM   #8
We recently purchased an ACOPOWER compressor cooler, which uses an LG compressor. The model I selected has a built-in lithium battery that will keep it at 37 degrees + or - for around 14 hours. We used it this weekend found that the battery and 45w solar panel on our Campster kept it going well while we were driving. Our campsite was in the trees and the sun was mostly blocked by smoke haze, so I topped it off with the generator when we had it fired up for other reasons.
Our Campster came with a small dorm fridge, which was not useful while traveling or when boondocking. I took it out and reused that space. The only downside of the new cooler is that it is not built in and we have very limited floor space. We have to leave some space for the dog, so we put it outside in a pop up tent/changing room. A minor inconvenience.
Dave Fish is online now   Reply With Quote
fridge, trillium
Bar fridge install? maxypantsinyk Modifications, Alterations and Updates 12 08-21-2017 08:49 AM
Scamp Fridge Removal Ideas summer scamp Modifications, Alterations and Updates 22 07-28-2016 05:39 PM
Fridge cools better on 110v than propane? any Ideas Jim in arkansas Problem Solving | Owners Helping Owners 4 08-20-2012 08:22 AM
Winterizing an electric bar fridge? Cory Lewis Problem Solving | Owners Helping Owners 5 11-23-2010 07:03 AM
Round Bar vs. Trunion Mount Flat Bar WDH ? bobinyelm Problem Solving | Owners Helping Owners 11 07-06-2007 08:43 PM
