Bathroom light flickers when bathroom fan on - Fiberglass RV
Old 03-23-2021, 08:54 PM   #1
Trailer: 2021 Scamp
Hi All,
Everyone was so helpful in solving one issue I had with my new Scamp that I thought I'd try again.
This time I have an issue where the light in our bathroom flickers when we turn the bathroom fan on. It's a pretty constant flicker, probably 3 times per second. If I turn on the light right outside the bathroom over our top bunk, the flickering stops. So it only happens when both the fan and the bathroom light are on, and the light outside the bathroom above our top bunk is off.
Any ideas on what the issue may be?
Thank you,
Tom
teg_76 is offline   Reply With Quote
Old 03-24-2021, 03:33 AM   #2
Raz
Raz's Avatar
Vermont
A guess
LED lights? Are the "bulbs" removable. If so, try swapping them. Try a different bulb in the one that flickers. LED lights require support electronics to operate properly. I'm guessing the support electronics in the flickering bulb is malfunctioning.
Old 03-24-2021, 10:27 PM   #3
Trailer: Trail Cruiser
Ground problem?
Old 03-24-2021, 11:22 PM   #4
Trailer: 2021 Scamp
Thanks Raz! Iíll try switching them in the morning and let you know how it goes.
Old 03-25-2021, 05:49 AM   #5
AC0GV's Avatar
Wisconsin
The answer to the next question
Slide the cover away from the switch to remove. Also check the voltage with the problem occurring.
AC0GV is online now   Reply With Quote
Old 03-25-2021, 11:11 AM   #6
John in Santa Cruz's Avatar
Mid Left Coast
cheap LED lamps just have series load resistors, and aare quite sensitive to voltage fluctuations, causing flicker. good ones have current regulators, and won't flicker at all. these 'good' ones will have a specification like 'Voltage: 9-18 volts' or maybe even wider.
Old 03-25-2021, 12:56 PM   #7
AC0GV's Avatar
Wisconsin
My LED problems
My LEDs with the wide voltage range were under 1$ each but caused interference on radios. The 12 volt only were 5 - 6$ @ and are quiet.
921-WWHP9-DAC and 921-WWHP12-DAC from superbrightleds.com
Old 03-25-2021, 01:52 PM   #8
Raz
Raz's Avatar
Vermont
The op said "If I turn on the light right outside the bathroom over our top bunk, the flickering stops"
Since turning on a second light would cause additional loading, I'm guessing the problem is not voltage. I think the regulator in the bathroom light is oscillating at a frequency other than designed. Turning on the other light stops the unwanted oscillation. Probably a bad capacitor or cold solder joint on the offending light.
Old 03-28-2021, 04:14 PM   #9
Everywhere
As someone with just enough electronics knowledge to be dangerous, maybe the second set of lights has enough input smoothing to help with the noise caused by the fan motor?
Old 03-31-2021, 11:57 AM   #10
Trailer: Ventura 1973
Calgary
Here's a thought, although perhaps not a correct thought.
I too am having similar issues and am planning on trying to find the cause this weekend in my 1973 Ventura.
Do any of you electrical types know if the issue could perhaps be that the light and the fan are wired incorrectly? For example, if wired in parallel and it should be in series, or vice versa?
Parallel49th is offline   Reply With Quote
Old 04-01-2021, 04:18 AM   #11
Raz
Raz's Avatar
Vermont
It's been a week since the OP posted. I do hope he tells us what he's found. How many times do you have a problem, find a thread that discusses it but never get a solution because the OP never posts the resolution?
Old 04-01-2021, 05:33 AM   #12
Have 2 separate projects going on 2 different trailers and purchased 2 6 pack sets of touch led flush mount pot lights from amazon for $50 bucks a set . One trailer has a brand new converter and one converter is original from 1977. The new converter works the lights just fine with no issues while the lights I put in with the old converter flickered almost right away and they all blew out within 10 minutes and will no longer work. reinstalled the original RV lights with new led bulbs and they work perfect so there must be led lights that are very sensitive to voltage fluctuations and some that are not .
Mikmay is online now   Reply With Quote
Old 04-01-2021, 05:49 AM   #13
Massachusetts
I'm not an electrician, but I did stay at a Holiday Inn ......
Note the the OP does not specify LED or incandescent bulbs.
Note that LED voltage sensitivity theories (presuming that LEDs are in use) have to hold true with all three states of bath light only (no flicker), fan and bath light (flicker), and with fan, bath light and bunk light (no flicker).
Not specifically stated, but inferred, is a fourth condition of bath and bunk lights, no fan, with no flicker.
I'm going to presume the fan is a 12 volt DC powered unit with brushes and not an inductive (brushless) motor AC unit.
Is one of the rotor contacts in that DC motor not conducting, thus not drawing power for that brief instance as the motor momentum carries it past the dead spot to the next good contact? The change of current draw from power to dead to power will affect the voltage a bit.
Tom, if you're still around, switch on the bath light check for flicker. Hold the fan from turning and then switch the fan to ON. Does the light flicker? Rotate the fan by hand while the power is still on. Is there a fan blade position that causes a change in the light intensity or does the fan motor force you feel change?
Is the bath light LED and faster to react to very brief voltage changes as the fan passes a motor dead spot? Is the bunk light bulb an incandescent that not only is slower to react to fan influenced voltage change, but draws enough power that the voltage drop it adds when on masks the brief removal of voltage drop of the fan as is passes a motor dead spot?
Jon MB
Bonnie RB is offline   Reply With Quote
Old 04-01-2021, 06:54 AM   #14
And how many times do you see OPs start multiple threads with the same or related questions?
I can't be sure but I would bet that the cause is the same as the other electrical issue he reported (and fixed) at the same time:
https://www.fiberglassrv.com/forums/...rly-95148.html
BTW, the problem was an unplugged converter... so this flicker was likely due to low voltage from a depleted battery.
Old 04-01-2021, 07:42 AM   #15
Raz
Raz's Avatar
Vermont
Could be but why would the flickering stop when he turned on the second light. Turning on the second light would make the voltage even lower?
Also, in the thread you referenced he "fixed" the converter problem on the 23rd March but is still working on the flickering here on the 25th March. Beats me?
light
Fantastic fan orrrr the Max air fan? DonnaMarie Problem Solving | Owners Helping Owners 47 04-10-2021 10:21 AM
Which Fan-Tastic Fan? (for a 1985 Casita) rebeccasf Problem Solving | Owners Helping Owners 24 09-05-2020 10:10 AM
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Fan-tastic Fan Seller - Best Price I Found barryra General Chat 1 07-11-2011 04:51 PM
Fan-tastic fan Ken&Chris Problem Solving | Owners Helping Owners 13 04-11-2006 07:15 PM
