Belt line seal leak - Fiberglass RV
Old 06-22-2020, 12:29 PM   #1
Trailer: 1975 Ventura
Yukon
Belt line seal leak
Does anyone have experience with the belt line seal letting in water?
sonny75 is offline   Reply With Quote
Old 06-22-2020, 01:50 PM   #2
Trailer: 2018, 21ft escapeó 2019 Ram 1500 Laramie
No ; but that’s probably cause I never heard of a
“ Belt line seal “ !
Old 06-22-2020, 02:10 PM   #3
Of course he means what is more commonly called the belly band, and yes, it can leak. Itís more common on some makes than others depending on how the halves are joined. I donít know about the Ventura.
Window and vent leaks are more common, and since water can travel some distance from the source before appearing, Iíd rule them out first.
A garden hose on trickle or a watering can with a narrow spout allows you to target potential leak points. Work from the bottom up, and allow time for water to appear before moving on.
Old 06-22-2020, 04:19 PM   #4
Google. Belly band on Trilliums is a well known defect and removing the band, grinding out all the plates, and patching the fiberglass is the time tested repair.
Love my Trillium but they had some serious design flaws that have to be repaired: belly bands, rotten wood around windows, rotten wood where door hinges attach, and body to frame bolts. Pre 1976 had a recall for their frames. Front body bolts went right through frame at the same place frame was mechanically bent. Frames cracked.
First thing I look at when I see pictures of a used belly band. If it still has the old trim, I know I will be grinding and patching.
Seeking Trick to Finding Air leak in Water Line? Kirby C Problem Solving | Owners Helping Owners 4 08-23-2019 11:07 AM
possible gas line leak to refridgerator garycarolyn Problem Solving | Owners Helping Owners 7 05-31-2017 10:25 AM
Snow Belt in UP of MI, driving on snow packed roads? nrthwds Care and Feeding of Molded Fiberglass Trailers 24 10-01-2015 02:16 PM
rubber line vs metal line CarmichaelBee Problem Solving | Owners Helping Owners 3 07-08-2015 10:50 PM
First trip under our belt ! Screaminge Problem Solving | Owners Helping Owners 6 08-12-2013 10:17 AM
