Best chocks and advice for parking Scamp on hillside in windy area? - Fiberglass RV
RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-19-2021, 10:23 AM   #1
Trailer: scamp 13
I often have to camp in areas where there are ridges, ravines and sometimes high winds. I have never had a problem, but I figure I don't want to learn the hard way and find my Scamp 13 in a ravine somewhere. So I thinking that chocks are like boat anchors, and I should get something really good and trustworthy for when I have to leave the Scamp unconnected from its tow vehicle (4R-4WD). Any advice is welcome? What are some really good chocks I could buy. What else can I do to insure my Scamp doesn't move in high winds (often 40 knots, occasionally up to 70 knots). Would love to get advice.
zack sc is offline   Reply With Quote
Old 01-19-2021, 10:46 AM   #2
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
For really heavy winds, tie downs would be the best option. The problem won't be the chocks, it will be the wheels slipping off whatever you use to level the trailer from side to side (boards, those Lego-like blocks, etc.). In a 70 knot gust to the side, your trailer will be pushed off.
Alex Adams is online now   Reply With Quote
Old 01-19-2021, 10:50 AM   #3
A BAL leveler is less likely to slip than blocks for side-to-side leveling. It’s a device the cradles and lifts the wheel. Also look for heavy rubber chocks, not the hard plastic kind. Once you put weight on the stabilizer jacks, it’ll be less likely to move. You could add a second set of stabilizers under the front of the cabin. Park nose into the wind when possible.
In extreme conditions, best to leave it hitched. (Plus all the above.)
Old 01-19-2021, 11:03 AM   #4
We bought a BAL leveler and added front stabilizers to our 2013 Casita
With the BAL and all 4 stabilizers deployed we had no issues with movement even in strong storm winds
If you are concerned about tipping , fill your onboard water tanks and use them as ballast .
steve dunham is online now   Reply With Quote
Old 01-19-2021, 12:18 PM   #5
Trailer: Trail Cruiser
I only park on reasonably level ground and always use a chock between the wheels on both sides. I also removed the wheel from the tongue jack. It doesn't take much of a grade for a detached trailer to move and once it starts to move its a lot of weight to stop. I've seen this happen a couple of times. If you pull the break away switch it will lock the wheels as long as the battery lasts.
Trailers have all the aerodynamics of a brick. A strong side wind will rock the unit or sometimes tip it over. The best thing to do in high wind is to attach the trailer to the tug and orient them towards the wind.
Old 01-19-2021, 01:41 PM   #6
Originally Posted by Mike_L View Post
I only park on reasonably level ground and always use a chock between the wheels on both sides...
Just to be clear: chocking between the wheels is only applicable to tandem axle trailers. The OP has a single axle Scamp. 13. For that the BAL is probably the best option. Here's a picture. You would use this on the low side and a pair of heavy rubber chocks on the high side.
Name:	BAL Leveler.jpg
In really bad conditions you can also dig in the wheel on the high side (where permitted in some backcountry locations). You'll still want the chocks. Be sure to fill the rut when you leave.
One additional tip when unhitching in windy and/or steep conditions: leave at least one safety chain attached until the trailer is leveled, chocked, and resting on stabilizers. Once it's completely set up, the risk of unwanted movement is slight, and you can then detach the safety chain(s).
Old 01-19-2021, 03:51 PM   #7
Best Advice:
Join GoodSam and get an insurance policy on the camper.
Ordinary insurance companies might not give you a replacement policy.
Old 01-22-2021, 02:22 AM   #8
Everywhere
Heavy-duty chocks are good advice. Plus face into the wind if possible.
It might also be worth running the emergency brake cable to a stake, like one of those dog leash corkscrews. That way if it does start to roll any distance, it'll stop itself as long as it's got battery. It's no substitute for heavy-duty chocks or even tie downs, but an extra layer of protection is always good.
Old 01-27-2021, 02:35 PM   #9
Timber Wolf's Avatar
North Florida
While Idon’t like doing it and it may not be possible in all situations, digging in the “high” side might be better than jacking up the low. Just fill it in when you leave.
Old 01-28-2021, 11:19 AM   #10
Trailer: scamp 13
cool idea. thanks.
Old 01-28-2021, 11:38 AM   #11
Originally Posted by zack sc View Post
cool idea. thanks.
Just be aware it's not allowed in most developed campgrounds and high use areas. It may be okay in some dispersed camping locations; local rules vary. Check before you dig.
Old 01-30-2021, 07:44 PM   #12
Borden's Avatar
Name: Borden and Carole
Originally Posted by Darwin Maring View Post
Best Advice:
Co-op in Canada has trailer insurance for season available. Includes liability and optional repairs; it is affordable. They want to check condition and have appraisal value done with repair option. Will have to check on replacement? Replacing vintage unit and rebuild cost could add up. Have not tried GoodSam as we have our house, cars and bikes with Co-op. Will have to go online though and check them out. Thanks for info on GoodSam.
1978 Ontario made Boler
Towing on windy bridges Weavery Problem Solving | Owners Helping Owners 8 10-27-2016 06:28 AM
Trailer chocks and level blocks ZachO Care and Feeding of Molded Fiberglass Trailers 42 04-20-2016 04:24 PM
LA parking or RV park, or hotel with good parking 55goddess General Chat 8 12-29-2015 02:05 PM
Was towing this weekend and was awfully windy deryk Towing, Hitching, Axles and Running Gear 82 05-16-2013 07:03 PM
Windy Visit! Sue and Henry Camping, Campout Reports 0 04-18-2013 07:41 PM
