Bigfoot "bench" lid removal - Fiberglass RV
Old 07-13-2020, 01:01 PM   #1
Trailer: 1990 Bigfoot B19
Another of today's minor frustrations. I am putting in a small 2.5 gallon 120V mini-tank water heater. The space where the original Atwood was (may it RIP) is fine, but it is very awkward working in there. My thought was to remove the flip up lids completely - not just flip them up!) and that would open that entire space up. And then put it all back when I was done.
I removed the 4 Robertson screws from the side braces, (I will always talk about Robertson screw heads when I can ) but it won't budge. I am coming to believe that she was screwed and glued together.
Any suggestions as to how I might be able to open that space up to work in? Without taking a wee saw to things?
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Deb Mac is offline   Reply With Quote
Old 07-14-2020, 11:15 AM   #2
Name: Steven and Paula
glue issues
I am a renovator and have seen this kind of issue many times.
I have a multi-tool https://da.lowes.ca/webassets/images...12189029_l.jpg
This will be able to slice through the glue with no visible damage. Providing you stay steady with your angle of attack. Some times I put some tape on an area that the blade will rub against to make sure there are no markings.
Steven Potter
swip is offline   Reply With Quote
Old 07-14-2020, 02:26 PM   #3
Thanks Steven. I also have a multi-tool, so I will probably give that a try. These Bigfoots (and probably most other FG's from that era) were certainly built to take a beating. This little "bench" is about as solid a piece of construction as I have seen in a LONG time! I just need to get the assembly out of the way while I rig the pex and get a good mounting base set up for it. Then it can all go right back where it came from!
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
bigfoot
Boler bench and counter removal motorcarmike Problem Solving | Owners Helping Owners 2 08-13-2017 10:06 PM
99 scamp 16 vent lid camper1887 Care and Feeding of Molded Fiberglass Trailers 12 03-17-2012 08:39 AM
Exit Vent Lid Scamp RonnieV Classified Archives 6 08-04-2011 09:16 AM
Bigfoot Propane Compartment Lid Lost on Hwy Joshua Ills Problem Solving | Owners Helping Owners 3 06-27-2009 09:33 AM
Wanted, the fuzzy toilet seat lid cover Karalyn Problem Solving | Owners Helping Owners 2 05-06-2007 04:30 PM
