Bigfoot trailer leaking city water check valve - Fiberglass RV
Old 06-24-2021, 08:10 PM   #1
Trailer: 1990 Bigfoot B19
Having finally found the small leak that kept my pump cycling, I would love to replace or repair the check valve. Meantime I have it tightly capped.
However, the line coming in from the valve is completely hidden by the kitchen cabinet.
Before I start making things worse by willy-nilly taking off the valve from the outside, does anyone know how the interior plumbing is connected to the back end of the valve? I see the original grey poly going up behind the cabinets, but what there is at the connection, I canít see. Even with my SeeSnake.
Anyone know the best way to approach this particular problem?
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Deb Mac is offline   Reply With Quote
Old 06-24-2021, 09:08 PM   #2
Trailer: bigfoot
Saskatchewan
Hi Deb, I had to replace the city water inlet on our 1981 Bigfoot 17 just last year. It was easier than I had hoped: it was just threaded on to a pipe behind it, and was all accessible from the outside. You'll probably want two wrenches to loosen & tighten the threads. I tried to find a photo, and this one from Amazon was the best one to show the threaded back side.
I removed mine and took it to a local rv store, who had to order the right style and color for me. I think it cost about $35CAD. A little teflon plumbing tape on the threads, butyl tape to seal the flange, and the new one was installed in a few minutes.
Hope that helps!
GeoffClick image for larger version
spartacus is offline   Reply With Quote
Old 06-24-2021, 09:37 PM   #3
Thank you Geoff! I’ll pull it tomorrow and see if I can get a match. If not, I should be able to fix it for the short term.
Drove me crazy trying to find the leak for 2 days. Everything inside was bone dry. Never thought of the check valve till I saw a damp spot on the ground.
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Old 06-25-2021, 10:20 PM   #4
Trailer: bigfoot
SK
good info
I also have a 1981 B17. Good info, thanks. I would mention that to access the plumbing on the inside I found the easiest way was to pull the stovetop and oven out. Disconnecting the gas line and removing a few screws allowed them to be slid out. Gave me a good look at the plumbing connections.
g4fishing is offline   Reply With Quote
Old 06-30-2021, 09:11 AM   #5
Replacement city water valve
Just thought I would pass this along to anyone in need. I did find a replacement valve on Amazon. Can't guarantee that it will fit everyone's Bigfoot, but if you pull yours and it looks like the pictures below, the perfect fit replacement was https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
Like Geoff said, it was a pretty straight forward replacement. The poly B connection is relatively deep set but in a big cut-out, so easy to access. I needed a small pair of vice grips on the poly connection. It's a square fitting, and the adjustable wrench just didn't give a good enough grip on the slippery poly. But the vice grips, on a gentle setting, worked perfectly. After 30 years it needed a bit of muscle to move, but it came off. After a few minutes with the tape measure, I found the JR fitting.
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
bigfoot
city water valve problem WDavidG Problem Solving | Owners Helping Owners 14 04-11-2018 08:52 AM
How I replaced my city water inlet and added a shutoff valve gordon2 Plumbing | Systems and Fixtures 14 04-05-2018 04:41 PM
City Water Inlet Leaking: 2012 Scamp 13 STD CampyTime Problem Solving | Owners Helping Owners 9 10-25-2016 06:52 PM
City Water Connection Valve is going nuts! Lee S. Problem Solving | Owners Helping Owners 6 05-07-2014 01:40 PM
» Trailer Showcase
N/A
Dick0736
1974 Boler
nlife
