Bigfoot trailer Location of monitor panel? - Fiberglass RV
Old 08-28-2020, 03:26 PM   #1
Trailer: 1990 Bigfoot B19
A quick question to those BF owners. Getting some measurements to swap in a new waste outlet in my B19 and I see wires and sensors on my grey tank (not sure of the black and fresh). Don’t know if sensors were always there and the monitor is optional, or, if there is/was a monitor panel in my old trailer, where I might start looking for it, or the wiring.
Thank you 😊
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Deb Mac is offline   Reply With Quote
Old 08-28-2020, 04:28 PM   #2
ZachO's Avatar
Trailer: Sasquatch
Montana
Looks like the monitor panel was optional, but I guess they're all wired for it.
It would be on the range hood, right over the stove.
Old 08-28-2020, 04:37 PM   #3
ZachO's Avatar
Trailer: Sasquatch
Montana
Since I already have it out; in case it's helpful.
Old 08-28-2020, 04:42 PM   #4
Thanks Zach. I there’s nothing on my range hood, or even close to it, so likely all pre-wired. Might be thru to the interior or just local at the tanks. I’ll go searching tomorrow while I’m on my back under the black tank. ��
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Old 08-28-2020, 04:54 PM   #5
ZachO's Avatar
Trailer: Sasquatch
Montana
Sounds like fun...
Old 08-28-2020, 05:11 PM   #6
Originally Posted by ZachO View Post
Sounds like fun...
Yeah. SO looking forward to it .
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Old 08-28-2020, 08:06 PM   #7
Trailer: 1986 Bigfoot B19 Deluxe
Hi Deb,
I just purchased a B19 and it has the monitor.
Mine is in/on the wall between the stove and the fridge. (facing the stove to the left of the stove)
It's center is approximately 19" above the counter and roughly in line with the two front burners or the face of the cupboard above the stove.
Hope this helps,
Scott
ScottBC is offline   Reply With Quote
Old 08-28-2020, 08:14 PM   #8
Thanks Scott. Yes it does! Since I very obviously (now) do not have, and never have had a monitor, I’m going to take a look at installing a monitor. Wiring is there, so I may as well take advantage of it. These are fairly generic sensors from what I understand, so should be able to install a compatible monitor.
Another low priority “would be nice” job for the to-do list.
Deb
1990 Bigfoot B19
Logan Lake, BC, CAN
Old 08-29-2020, 07:53 AM   #9
ZachO's Avatar
Trailer: Sasquatch
Montana
Oh yeah, it's definitely a very basic thing. I don't know much about electronics, but I've been forced to trouble shoot and fix things a few times since I usually own old vehicles and old campers.
I don't know exactly how they work, but I'm guessing it's just like installing an aftermarket tachometer or anything like that. There's a signal (or not, if there's nothing in the tank) coming from that wire. The monitor will know what to do with that signal.
The gauges really are nice.
Old 08-29-2020, 02:10 PM   #10
On my 1989 B17 the monitor panel is on the wall beside the stove about the same height as the hood fan. Good hunting.
burrorojo is offline   Reply With Quote
bigfoot
Monitor Panel wires on the other end Gardnpondr Problem Solving | Owners Helping Owners 27 05-05-2015 09:00 PM
To Monitor or NOT to Monitor Darral T. Plumbing | Systems and Fixtures 15 10-13-2014 07:22 PM
Battery Monitor... solar controller monitor? LukeP Modifications, Alterations and Updates 5 05-14-2012 10:54 PM
Solar Panel Location Fred Modifications, Alterations and Updates 8 01-17-2007 10:26 PM
