boler 1300 frame rebuild material - Fiberglass RV
Old 08-17-2017, 07:20 PM   #1
Hey all,
i am in the process of planing a new frame for my 13' boler. i was wondering what the best material would be to use? i have a 1969 so it has the original flimsy frame.
3" C channel?
1.5"x3" thick wall tubing?
any help or suggestions would be great.
thanks
mike
motorcarmike is offline   Reply With Quote
Old 08-17-2017, 07:31 PM   #2
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Check this site out: Boler Modification Ideas & Projects - Boler-Camping
Old 08-18-2017, 04:34 AM   #3
thanks, ive seen that link. i dont like the idea of 6" rails. I was hoping to use a stronger steel but keep the stock look of the original frame. thats why i was thinking about the c channel or the thick wall tubing...just not sure what would be better.
Old 08-18-2017, 07:24 AM   #4
rbryan's Avatar
Arkansas
Mike, I seriously doubt you could improve on Ian's design, or find a more suitable material. His details about how and why when building a Boler frame are the best I've seen - anywhere.
Boler Frame - Boler-Camping
Old 08-18-2017, 05:40 PM   #5
Oh i have no doubt that his design is strong and works. I just think its a bit more work than needed for a boler. Would you not get the same result using structural thick wall tubing? like 1.5X3" or 4"? with alot less work?
I have a heavy duty tandem axle landscape trailer that is made with 4" Channel and ive seen 24'+ camper trailers made in a similar fashion.... i even think 1.5"x4" thick wall tubing is overkill for the weight of a boler...
So im guessing that no one has made a new frame using tubing?
Old 08-20-2017, 08:52 AM   #6
rbryan's Avatar
Arkansas
The original Bolers apparently used 1.5x3, as Ian points out on his website. That's strong enough per se, but anything that prevents potential bending or twisting of the frame as the trailer bounces down the road is a good thing in my book.
Old 09-06-2017, 07:44 AM   #7
jcstanley's Avatar
Trailer: 30' jayco & 1974 Boler
the original Boler used 1.5x3 16ga tubing . not strong enough for 45 years of abuse . I added 1.5x3 1/8 tubing under the original frame , and welded it together . by clamping things together before welding the heavy tube will help to remove sagging and twisting . use string lines to checkout weather or not you have sagging and twisting .(you will) if you are not comfortable doing this get a professional . check out my registry to see how i did this . also consider replacing the axle when you do this , because now you can flip the axle to the trailing position . good luck !
jcstanley is offline   Reply With Quote
boler
Boler Frame rebuild Azurko Modifications, Alterations and Updates 9 03-06-2016 06:13 AM
Yards of material required for Trillium 1300?? stefman Problem Solving | Owners Helping Owners 9 11-29-2015 03:54 PM
16' 1981 Scamp frame off restoration/rebuild IdahoScamper Modifications, Alterations and Updates 24 06-04-2013 09:47 AM
What is the material between floor and frame DannyH Care and Feeding of Molded Fiberglass Trailers 2 10-06-2009 08:02 AM
Frame Material BrendaD Problem Solving | Owners Helping Owners 0 05-27-2009 11:57 PM
