Boler 1700 door seal - Fiberglass RV
Old 05-03-2021, 03:41 PM   #1
Hey folks. I purchased new black seal for my Boler 1700 door. The original seal was attached to the door itself (inset a few inches from the outside edge all the way around. But I have been noticing in lots of pictures that in most cases the seal is attached to the door jamb rather than the door. I wanted to know if there is an advantage to doing it this way. I am also concerned that the seal that was on my Boler were actually not original and whomever installed them possibly didn't do it right (lots of weird mods to my unit that don't appear to be "factory"). Any insight would be helpful.
TBlevins is offline   Reply With Quote
Old 05-03-2021, 04:49 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
The Boler 17 was built with two door types: curved molded fiberglass and flat aluminum skin. That affects the type of door seal. Which type of door is yours?
John in Michigan is online now   Reply With Quote
Old 05-03-2021, 06:38 PM   #3
Borden's Avatar
Name: Borden and Carole
Trailer: 1978 Earlton boler 1700 RGH
Door seal fist defence against bugs
Ours had a seal all around the cut out area on inside that has the shape of the body door hole. Think it maybe original and a car like foam seal that fit around door on inside between edge of door and body door seal. Think they added it because of the way the wall was out and down due to failure of connection from wall and plywood foor. Just fixing wall sag down and out closed most of the gap but we replaced hinge bolts and pivot balls with repair kit and added new foam to the door at same location as old gasket.
Our postage stamp in heaven.
Borden is online now   Reply With Quote
Old 05-03-2021, 06:52 PM   #4
Borden's Avatar
Layout and doors
We had a neighbour with a western boler same model as ours it had the flat inset door. Other differences it was lower to ground but the may have been the springs and was 2 1/2" shorter in overall length, side widow at sink swung out like yours instead of slider, awning like yours instead of roll out, only one power vent, rest of layout was exactly the same as ours right down to the 4 burner oven. 1978 RGW 1700
boler
New door seal installed, no seal at top of door. Luxus Panzer Problem Solving | Owners Helping Owners 4 05-11-2018 05:18 AM
Gap in Burro Door Corner / Door Seal wxmixte Problem Solving | Owners Helping Owners 1 10-31-2017 05:26 PM
1978 boler 1700 door hinges Dennis Hannaburg Problem Solving | Owners Helping Owners 5 06-09-2014 08:13 AM
Does a 10'x10' First Up clear the door on a Boler 1700? ShawnKK Problem Solving | Owners Helping Owners 36 06-10-2013 05:39 PM
